Car won’t start
Car won’t start
Just finished cleaning carb from valves. Worked for a few drive cycles all of a sudden last time I turned off car walked away to lock car remote wasn’t responding. Came to start car ignition light worked for a brief second before car powered down and moved steering wheel down. Key fob light blinks but car doesn’t respond to any buttons on the fob. Car doesn’t start when key fob is next to push to start. The car doesn’t even turn on the dash lights. The only light that comes on on the dash is when the door is opened. Security light is on when car is locked and turns off when opened using metal key.
Interior lights, headlights, door locks work. Radio and dash and power windows don’t. Tested battery at autozone and they said it’s a good battery. Jumpered the starter wires and the starter is working. Checked basic small fuses they all work in the passenger/driver/next to battery fuse box. Going to try the the relays/fuseable link next. Has this happened to anyone?
Also went ahead and changed the fuel pressure sensor and still no go! Connected tech stream and it won’t show anything says all my ecu’s are down (no status) please help me I don’t want to tow the car to a dealership.
link to video
If you click on the keyfob to lock and unlock the door and nothing is happening, then first replace the battery in your keyfob.
Similar incident happened when my keyfob battery was going out.
The coin shaped battery should be "CR1632".
There was a video you posted with the is250, the mechanic unplugged one of the plugs on the ecu and that allowed the ecu to reboot. Have you tried that?
I have trust issues with cheap china parts off ebay, the ones sold in big box chain auto parts are more trust worthy imo.
no I haven’t which video?
Notice how the ecu resets itself and the fuel pump kicks on
https://www.youtube.com/watch?v=eENs...ature=emb_logo
I unplugged that wire and i didnt hear the fuel pump or anything but I still went ahead and changed the fuel pressure sensor cause it was only $20 but it didn’t fix the problem.
Do you think the alternator can cause this? I read that the alternator won’t stop your car from starting?
it doesn’t reset the ecu though does it? its only to check for the fuel pressure sensor no?
The reason for him unplugging the harness is because to test if theres a short in the wires. In his case the fuel sensor was being shorted out. So by him unplugging that plug on the harness it allowed the ecu to reboot and not detect a short in the wires.
If the battery voltage is above about 12.7 volts the car should start even if you disconnected the alternator. Test the battery voltage! Worst case call a mobile mechanic to help you out, instead of throwing money at parts. This why it can properly get diagnosed.
turns out it was the fuseable link! jumpered from the fuseable link to the battery and car turned on! do i need to replace the entire box or just the fuseable link (the metal part)?
the relays and fuses work on the rest of the fusible link box!
