2006 front lower control arm bushings
Does anyone have the specs for the front rear lower control arm bushings on a 2006 lexus Gs 300 ? Please help..thank you.
What do you mean by specs? That front lower control rear bushing is common to go out, but it usually doesnt show that its bad. If your car is tracking from side to side on rough roads then more likely that bushing is bad. These bushings are cheap at the dealer, and super easy to replace. But you need to do a front wheel alignment right away.
https://www.ebay.com/itm/NEW-GENUINE....c100009.m1982
Triple C
02-09-10 11:06 AM
