06 GS430 Relay LED Flasher Fix
Hi everyone! I wanted to ask if any of you are aware of a relay LED flasher fix that allows you to retain the confirmation unlock/lock?
Looking through the forums, one person has mentioned that the relay from Think-Designs.jp was able to retain the confirmation unlock/lock. I have contacted them since the link provided from another user was not working, and unfortunately, they have discontinued it.
I really don't want to go with the resistor approach, so I wanted to get some ideas before I make a decision. Thank you!
Yes, it’s called the Smart Tap Flasher relay. It will modernize your flashers using LED turn and hazards without the hyper blinking. It retains the unlock and lock blink along with a courtesy light that stays on for 10-90 seconds based on your preferences. You can install it yourself but it a chore to reach behind the dash.
Here is an old thread. And remember, the module you want is the Smart Tap. The regular LED flasher module costs about $15. The advance Smart Tap is about $70.
EDIT: for some reason I could not post the link to the thread but you can find it by searching “FLASHER LOCATION “
NormzGS350 (02-14-22)
sttrieu
RX - 1st Gen (1999-2003)
04-05-18 11:18 PM
