2007 GS350 won’t start
3rd Gear
My GS will start and shut off immediately. After that it will not start again only fan coming on. If you wait a few hours car will once again start then die immediately. P/S, BRAKE & VSC light on. Anyone else had this problem
code reader pulling no codes
Sounds like your fuel rail sensor is bad, that is a common sign when the radiator fans kick on and the car isnt running. The 5v reference from the sensor is grounded out and shortening the ecu which is why the car is not running. You can disconnect the sensor plug and reconnect it and sometimes they start.
