New Battery New Alternator Still Not Charging 2007 GS 350
10th Gear
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
My alternator is not charging on my 2007 GS 350, I took it out and tested and it says it was a good alternator, I'm also not getting the (check charging system light or battery light not coming on ). I decided to just replace the battery and alternator since I took the old one out. When I replaced them it was still not charging and the battery was completely dead. I also notice my park asst, park lights, turning signals, speed sensor, and gear position sensor wasn't working either, the green light that usually turns on depending on the gear you are wont turn on. I got a few codes but those codes are coming on because some how they are not getting power, also my power steering IS also really hard, it is like if all those are not getting power somehow. I have checked the fusible link and is good, I tested and it tested good, I have checked all fuses on the car, front passenger and driver side, inside the car left and right, and the one in the trunk, they all are in good condition...ECU is good is there two fusible links ?? on the wires but I can't find it... the only fusible link I know is the one on the Rigth front fuse box.. ?? I really need help !!! $ 1700 down the drain !!!
bettis504
Southeast
09-10-22 06:54 PM
