How to upgrade headlights to the 3-projector version
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Hi and welcome.
I've moved your post out of the big modification thread where it will get lost.
If you try using search in this forum, just look for 'headlights' in thread titles you'll find a number of threads on this topic. Here are some examples I found by searching, there are more
https://www.clublexus.com/forums/gs-...ht=triple+beam
https://www.clublexus.com/forums/gs-...ght=headlights
Forum Administrator
https://www.clublexus.com/forums/search.php
jgscott (03-03-23)
https://www.clublexus.com/forums/gs-...turn-30-a.html
F-sport it's not plug and play, like 450h or non-fsport
I'm assuming you're converting from 2014 to the triple beams 2016+? If so, it is no plug and play, extensive wiring is required.
2016+ to triple beam is plug and play, but you need Techstream though.
https://www.ebay.com/itm/394310046782
https://www.clublexus.com/forums/gs-...eadlights.html
https://www.clublexus.com/forums/gs-...l#post11395187
https://www.clublexus.com/forums/gs-...l#post11395188
https://www.clublexus.com/forums/gs-...l#post11395229
@MHAYBURN14 you can also do the aftermarket triple beam LEDs as well which are plug and play. @JoshIS408 has them on his 4GS and gave a positive review. Here are some links:
