2018 F-Sport AWD Rotor Part Numbers
Greetings,
My apologies if this info is mentioned somewhere already, but I couldn't find it doing the applicable searches.
I have a 2018 F-Sport AWD, and I'm preparing to replace my front brake pads (using the Akebono ACT1118... please interject if I should stick with OEM pads for my AWD) and rotors, but I wanted to be sure I have the correct part numbers for the rotors.
I called a few local dealerships, but they said they aren't allowed to give me the part numbers, but here's what I found:
Pads:
Akebono ACT1118
Anti-Squeal Shim Kit:
04945-30360
Rotors:
43516-30041 (Driver)
43512-30351 (Passenger)
Thank you for any confirmations and recommendations offered.
Pads:
Akebono ACT1118
04945-30360
Rotors:
Last edited by Mattside; 03-05-23 at 08:25 AM. Reason: Updated the rotor part numbers
I believe the akebono's come with their own shims . . .
I would use OEM pads and any decent rotor. But good luck either way.
Greetings,
Pads:
Akebono ACT1118
04945-30360
Rotors:
Pads:
Akebono ACT1118
04945-30360
Rotors:
That might have been me I recently replaced rotors and pads (ACT1118) and used the Akebono supplied shims but had bad squeal every time I came to a slow stop. I then installed the Anti-Squeal 04945-30340 and no squeal since, going on about 1k since installing the new shims and still no squeal.
I just decided to order the OEM pads to be completely safe.
