2015 GS350 ML Stereo ASL feature doesn't work at all
9th Gear
Hello all, just got a 2015 Gs350 with ML stereo, I am wondering if the ASL feature ever works in your stereo? I believe mine literally doesn't work at all. I tried to switch the ASL on/off when doing 65mph and the volume of sound made no difference. I also have a 2011 rx350, the ASL works fine even when roll down the window the volume is noticeable becoming higher, the rx350 has the Pioneer Stereo.
Mine's worked not perfectly but I could tell because I turned if off. Does your mic work? I think it uses the same mic for voice commands.
9th Gear
Same year , 2015 f sport rwd
9th Gear
I have seen some people saying their Toyota's with JBL stereo the ASL also doesn't work. Most of those cars have Pioneer Headunit but Probably JBL amps.
9th Gear
Correct, it is pretty plug and play. ML speakers have higher ohms and much higher sensitivity, so if you turn the volume to 10 using the pioneer amp, it is already really loud. the way I fix it was adding power resistors for the speakers. You also need to get a harness and then soldering the resistors inline. Right now my pioneer amp see 12 ohm for each speaker expect the subwoofer and the volume is normal. The last thing is to connect the front dash and rear deck speakers in series since pioneer amp doesn't output signal to the rear deck speakers
sheriffwoo
10-17-16 06:37 PM
