Wheel gap solutions
Hello,
I have a 2016 GS350 F Sport RWD and I am hating my rear wheel gap. I tried RSR downs lowering springs and the ride was so rough I ended up putting the OEM springs back on. I like the softness of the car and I drive long distances and not sure if I want to gamble with other springs/coils.
Question
Is it ok to put bigger tires to fill the gap and how does this affect the safety/drivability?
Stock: Front: 235/40ZR19 / Rear: 265/35R19
Possible upgrades: 275/50/19 or 275/55/19 for the rear. Or what other sizes will work best? Also, I am ok just doing the rear and keeping the front stock as the front gap is good for my taste.
Appreciate all the suggestions!
Question
Running a 50 or 55 in the rear, it's gonna look massive lol. It's not gonna affect ride safety/drivability. It'll make the ride a lot more comfortable cuz you'll have meatier tires. I'm on coils, so no more wheel gap lol
I doubt a 275/50 would even fit in there, it would be massive, I know you supposed to keep within 9mm of stock diameter but people run bigger with no issues it seems, just be weary if you do go bigger your ride height will also go up slightly and, with a 275/50 or even 275/40 the car will look very nose down if you don't change the fronts too.
I think even going to a 275/35R19 would be decent jump, with the stock setup you can tell easily the rear is a bit smaller than the fronts.
I'm planning to go 275/30R20 and 235/35R20 soon, considering 245 and 285 but not sure if there will be any issues. I'm on stock height with no plans for a drop though.
I think you’re the first person I’ve heard say the RSR Down’s were way too rough. Are you sure they were downs and not super downs? That they were installed correctly? I ask also because the lowering springs will be your cheapest way to eliminate wheel gap rather than purchasing a set of larger tires on all corners.
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x901/img_20230225_114349_1_82a0304cdcccceb59ad312f4b5e54ad0f4a5d342.jpg)
This gap ok with you? Rears are 275/35/20 on Swift springs. Rides a very tad tighter than stock. Mines a lux version.
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x980/screen_shot_2023_03_13_at_12_13_30_pm_7a5f05803ec0415506ddca74084c1a2518d2931a.png)
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x957/screen_shot_2023_03_13_at_12_15_57_pm_43aff1f649b59f9929a9d1cff96d9a6d386194f1.png)
This is the perfect look! I was thinking about the swifts but was not sure about the ride quality given everybody was saying the RSR was close to stock, which are not in my experience.
How's the ride from 1-10, 10 being the stock? Also, any issues with alignment/tire wear or steering pull?
I also tried to put rsr in the back and then switched back to stock. It was excessively harsh. Maybe swift springs are good. I don’t remember now from half a year ago but from what I kinda remember from website description rsr are around 8 kg / mm and swift like 6 kg / mm. Don’t remember exactly but remember that swift are softer/ closer to oem. And the rsr down and super down had the same 8 kg stiffness which doesn’t make any sense and I ended up just throwing them into dumpster.
I don’t recommend anyone who cares about ride quality on bad city roads to install rsr downs in the back.
