Rear spring rotation/orientation.
I just installed my RSR Down Springs, and, after spending 7 hours fighting rust in the rear (my whole body is one ache today), I realized that I did not pay attention at all to how I lined up the rear springs, just that they were in their upper and lower perches and right-side up. Based on the design of the perch and upper mount, I don't believe that the rotation of the spring should matter, but can anyone confirm?
Thanks.
Thanks.
I looked at the perch when I did mine and it looked the same, so I don't think it matters, as long as the spring is positioned in there correctly. I know what you mean about the PITA that job is. My car was not rusted and I was sore as hell too.
So......Did you reindex your control arm bushings after the spring install?
So......Did you reindex your control arm bushings after the spring install?![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I did not realize how much bind there was in the rear suspension. Fighting bushings to align bolt holes was my second least favorite part.
4GS350 (09-29-23)
That bad huh? I was thinking about doing my rears. I've never done shocks before but a youtube video I watched made it look pretty okay. Just the backs obviously, not touching the fronts.
To be honest, I only did the ones I had the strength to undo. I ended up not doing the main upper control arm, the body side of the forward upper control arm, or the body side of the rear toe link on either side. I was so bushed that I abandoned any thought of installing camber arms myself. If the alignment indicates they're necessary, I'll just pay to have it done.
@panyo64 . My springs have been on now for about 8 months and 7k miles. Is it too late to Reindex the suspension part bushing after this long and already having a alignment? Any benefit to still doing it this long later?
jgscott (09-29-23)
