Front LH wheel hit and out of alignment
Some clown drove into my 4GS front LH wheel and the wheel is now not perfectly centred in the arch. It’s more towards the back of the car rather than the front and cars pulling to one side and doesn’t drive straight. I need to take it to a shop tomorrow to get it inspected. Nothing visually looks very bent but I assume some arms and stuff may need replacing. Just as an idea what sort of parts will need replacing if a wheel was to be driven into ?
Okie Dokie! Apparently the good news is that there's no body damage. Sorry it happened, but good luck getting it fixed...
yes had two shops check it out and they say the lower control arm for sure and the spindle knuckle and possibly the upper control arm too.
I’ve managed to find a used lower control arm but the seller removed the ball joint because he needed that part. So wondering if I can transfer my original ball joint from lower control arm? Or is that likely to be damaged too?
DshngDaryl
08-04-21 11:13 AM
WLGS01
09-17-12 01:03 PM
