Lexus Noob here, suspension question
2nd gear
I am considering buying a 4th gen GS, do they all have the air suspension, AVS? From what I have researched I think the F sport and luxury packages have the AVS. I want to drive this next car until it gets to 200,000 miles so I would prefer not to have the complex suspension system. I appreciate the help.
It's not air, it's just a normal shock with a screw adjustment on top that the AVS control motor turns in Sport+ mode. Replacements are now readily available from KYB(same manufacturer as OEM shocks), set of 4 is about 300USD.
^ correct.
-Josh
-Josh
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
AVS stands for Adaptive Variable Suspension, which only means that the shocks constantly adjust in response to the road and stiffen when the car is in Sport+.
The front is a unequal length control arm coil spring strut assembly. This is a "coilover" in that the spring sits on a spring perch attached to the shock body, but is not height adjustable.
![](https://media.ed.edmunds-media.com/lexus/gs/2013/fe/2013_lexus_gs_det_fe_1241321_600.jpg)
The rear is multilink assembly with a separated spring and shock.
![](https://media.ed.edmunds-media.com/lexus/gs/2013/fe/2013_lexus_gs_det_fe_124137_600.jpg)
You can learn more here.
https://www.edmunds.com/car-reviews/...alkaround.html
E3PO (09-24-23)
