2014 GS350 gas pedal feels like there is a button underneath it
Test drove a 2014 GS with 93k miles, talked down to $17k before dealer fees (not gonna buy it just yet though until I get it checked out, so the deal isn't final and I can back out whenever I want to). When I floored the car, it felt like there were 2 stops to the gas pedal, like there was a button underneath that got pressed when the pedal was 3/4 the way down. None of the other Gs's I drove had this feeling. Is this something to be worried about? I feel like I got a pretty good deal, and I might be able to talk the dealer down a little bit more as well, but I'm concerned about this gas pedal issue. Everything else on the car works flawlessly.
Totally normal as my 2015 has this same detent switch under the pedal. From what i understand, along with my own experience, is that when you floor it and fully depress the switch it really awakens the beast within. Depending at what RPM and MPH you're at, it will accelerate to its full capacity by downshifting to the lowest gear it can along with using all 12 injectors 100% (Port Injection and Direct injection). I very rarely ever go full throttle, but when i do she really shows the power of the toyota 3.5L engine. Its also a good practice every now and then to give your car the "Italian Tune-up" treatment. This means full throttle your car for 3-5 seconds to blow out any carbon buildup that might be accumulating on the inner runners of the intake manifold and on top of the intake valves... More of a problem in engines that dont have direct injection. Watch your rear view mirror and you will see black smoke (carbon buildup) bellowing out the exhaust, to which you will notice a smoother idle when at a stop as well. Sorry for the long post on such a short answer... But i feel like its something people should know and try if your noticing any kind of ruff idle or sluggish acceleration 👍🏻. Always run the highest octane you can if in a hotter climate, as in the winter time you can get away with lower octane fuel.
Totally normal as my 2015 has this same detent switch under the pedal. From what i understand, along with my own experience, is that when you floor it and fully depress the switch it really awakens the beast within. Depending at what RPM and MPH you're at, it will accelerate to its full capacity by downshifting to the lowest gear it can along with using all 12 injectors 100% (Port Injection and Direct injection). I very rarely ever go full throttle, but when i do she really shows the power of the toyota 3.5L engine. Its also a good practice every now and then to give your car the "Italian Tune-up" treatment. This means full throttle your car for 3-5 seconds to blow out any carbon buildup that might be accumulating on the inner runners of the intake manifold and on top of the intake valves... More of a problem in engines that dont have direct injection. Watch your rear view mirror and you will see black smoke (carbon buildup) bellowing out the exhaust, to which you will notice a smoother idle when at a stop as well. Sorry for the long post on such a short answer... But i feel like its something people should know and try if your noticing and ruff idle or sluggish acceleration 👍🏻. Always run the highest octane you can if in a hotter climate, as in the winter time you can get away with lower octane fuel.
@Amisdia - Lexus GS 350 with 6-speed transmissions do not have the detent (kickdown) under the gas pedal. The GS 350 with 8-speed transmissions do have it.
There's nothing wrong with a GS 350 with 8-speed transmission that has a detent...
The detent has no direct control of the engine's fuel injectors, as that is controlled by the ECU.
Hope that helps explain it..
Yeah, maybe you didn't press the pedal all the way down. Or, if the 2015 GS 350 was an AWD model it won't have it because all AWDs have 6-speed transmissions.
A cold transmission not up to typical operating temperature will not shift like it will after reaching typical operating temperature. It will hold gears longer and may tend to hunt more often too, and might negate or disallow the kickdown switch operation.
