Wont start! But cranks! No communication! Cluster not working!
2nd gear
hello everyone i own a 2013 lexus gs350 luxury model and i was doing a little mod in the front end that involved a fuse tap. i accidentally made it spark while the car was running (it was tapped into the ignition fuse on the driver side of the car) and while the motor was running it died when it sparked and after that the car hasn’t been able to start only crank. radio works everything works how it should but the cluster when i click the button it should go to “Power On” mode and then a second click should initiate Accessory mode which my car will not do the cluster will not do the sweep nor turn on at all it is stuck on the “Power On” mode. Also No communication with a scanner
i have charged the battery and did replaced the dead IGN fuse and checked all other fuses to find nothing else. i have been going at this for a couple days now and have really no other options but to ask for some help on here. i’m in the DFW area but if someone anywhere knows or has had a similar issue please reach out.
@Ademk123 - I presume the IGN fuse you replaced had a visibly open (a.k.a. blown) fuse link, right?
It sounds like the fuel injectors are not receiving their trigger voltage signal to inject fuel. But there may be something more beyond just the IGN fuse you replaced that pertains to the ignition that is amiss.
Check the EFI fuse to see it it may be open (blown). Also, after replacing that fuse - if it is open (blown) - if the engine still won't start try swapping the EFI relay with another like relay (just like it) from the same fuse compartment.
Also, don't just look for the fuse dedicated for EFI, look also for EFI Main, EFI No.2, ETCS and INJ as well. In fact, it's best to check all the 10 amp, 20 amp and 25 amp fuses to see if any are blown (open).
It sounds like when you shorted-out the ignition switch wiring it may have taken-out the EFI fuse because the EFI circuit is closely associated with the IGN circuit, as are the relays.
I rather doubt your careless wiring mishap wiped-out something like the ECU or anything else that would be problematic to troubleshoot or expensive to replace. Let's hope not...
2nd gear
It sounds like the fuel injectors are not receiving their trigger voltage signal to inject fuel. But the may be something more beyond the IGN fuse you replaced pertaining to the ignition that is amiss.
bclexus (06-12-23)
mr29rose
SC- 1st Gen (1992-2000)
06-19-10 05:57 PM
adub1124
11-15-07 09:11 PM
