Fsport brake kit upgrade on base model?
I have a non-Fsport GS350 Sports Luxury 2016 and wondering if the braking performance on F is much better than base?
what parts are needed? I am assuming it would rotors, pads, and new calipers.
Is it possible to simply replace my rotors, pads and calipers or do I need new hubs and knuckles as well?
Has anyone upgraded their base brakes to Fsports?
tia
tia
tia
tia
You'll probably need more than rotors, pads and calipers. You'll need the dust shield, caliper brackets and maybe new lines if the original can't reach.
IMO, you would be better off with better pads and rotors.
I think I remember threads here where the Base/Lux to F Sport front rotors and pads were plug and play fit. There were already a few who have done it.
Now the GS F upgrade does require wheels that clear and dust shied mods, but I think there was 2-3 threads of those who just changed the Calipers Pads and Rotors from Base/Lux to F Sport and they just fit right on with the same lines, bolts and dust shied.
tia
tia
I do not care at all about dust, I just want pads that will not overheat and judder when I am heavy on the brakes, especially in the rear. I am on my second set of OEM pads and they are just not cutting it.
As someone who is in need of higher performance pads that will not overheat at the first sign of an offramp, do you have any suggestions (anything but Hawk, I have tried them on three different cars and hated the bite and feel)?
https://akebonobrakes.com/performance-vehicles
I ran these. They have a def difference in performance and are very good. My friend ran them on his 16 F Sport and said the same. They do put out more dust.
I have a set of F Sport New Stop Tech drilled rotors. I had them sent out and Cyro treated. I also have the upgraded Stop Tech lines. I plan to install the new F Sport bigger Cryo treated drilled rotors, with the Akebono Performance pads F&R, and have S/T Drilled rotors on the rear also with the Upgraded lines. I maybe one day will swap all out to the GS F brakes, but at this point I don't see the need. The GS F stuff is def on my bucket list though.
Yes but I was just sharing that these front pads def do improve braking over stock. You can feel and tell the difference. Have you upgraded your brake lines?
Next time around, I am planning on doing StopTech slotted rotors and a higher performance pad, something with factory like bite but higher heat tolerance as to not unevenly deposit all over the rotors.
Were the Akebono Performance Pads for the rear discontinued?
Unfortunately, it appears that the AWD front knuckles are different enough from the RWD/-F front knuckles that neither the RWD F-Sport nor the GS-F brakes will bolt on, and as of right now, nobody makes an adapter. I did factory pads and rotors at about 30,000, now at 47,000.
The other thing I was going to look at was trying to get some air cooling ducking to the front pads and rotors. The GS F uses this to cool the brakes. I was going to try to make some kind of DYI air ducts to the pads and rotors. Its works to help.
https://www.lexus.com.bh/gs-f-2016-p...-brake-cooling
overko
07-07-22 05:49 PM
