Clicking in the rear, CV Axle?
So… I’ve been dealing with vibration issues for a couple of months now. I got new tires and balanced it 4 times at discount tires, changed out the rear steering tie rod, and installed new rear upper control arm since the car is on coilovers.
Vibration still exists, so I decided to jack the rear up today and rotate the wheels only to hear click noises. The only thing that came to my mind is the CV axle. I’d like to note that the rubber boots are not damaged nor is it slinging grease anywhere either. The noise is not audible at all while driving, I just happened to hear it when it was in the air.
I remove the 32mm (I think) nut that holds the hub to the axle, use a slide hammer to try and get the hub off the spindle but it won’t budge.
Next, I removed the 4 Allen bolts behind the hub and tried the slide hammer again, but to no avail.
I need some help on other suggestions on how to get the hub off the spindle.
Lastly, does anyone know of any DIY on how to replace the cv axle? I’ve tried searching endlessly, but couldn’t find one.
Reference: 2013 fsport RWD w/145k miles
Thank you!
Thank you!
bclexus (06-21-23)
Thank you!
Thank you!
To see if this is your problem, raise your car's ride height by about ½" in each of two or three trial test segments to see if the vibration goes away. If your car has been lowered for the majority of its 145k clocked miles it may have clearly already received some degree of permanent damage, but raising the car's ride height might still help totally eliminate your vibration problem. If my belief is accurate you'll have to decide just how important it is to you to have a lowered ride height that propagates a menacing vibration that is obviously driving you a bit crazy. Let us know your findings...
I would bet you have bent rims. Go to a pro wheel place that can check with Runout gauge for a bent rim or 2-4. Most times 99% is a bent rim. Most regular tire shops won't be able to pick up a bent rim and will just balance to the bent rim. Needs to be spun and checked with a precision gauge.
ntwrkguy1
Suspension and Brakes
15
06-03-16 05:59 AM
steve1961
21
12-31-14 04:21 PM
