How do I wipe out all the radio presets?
No, I'm not getting rid of my GS.
Just want to start fresh, since I have a lot of junk stations and I want it to be clean instead of replacing them with unused radio stations.
Does the 'Delete Personal Data' wipe out the station presets too? Do we even have this feature in our GS? I haven't messed with the nav settings in a long time so I don't really remember.
And what else do I lose by deleting personal data?
I do not think there is any way to delete radio presets. You can overwrite them with new stations. However, you can remove stations in groups of six. If, for example, you currently have three groups of six stations, then you have 18 presets. You can remove a couple of the groups of six so scrolling via your steering wheel will only be for the remaining groups you elect to keep.
What does the Delete Personal Data actually delete? I don't mind losing my saved addresses and paired phones, I can restore them easily, just want the whole thing cleaned.
All the following will be erased:
- Phonebook data
- Phone sound settings
- Call history data
- Audio/video setting
- Customized image data
- Last used radio station
- FM info setting
- Contact List
- Call history setting
- Phone display setting
- Messaging setting
The following 2 users liked this post by bclexus:
Im2bz2p345 (06-22-23),
ItzFilyO (06-21-23)
OK that sounds like the one I need. Let me go to the garage and give it a try. Thanks BC!!
The following 2 users liked this post by PGA71:
bclexus (06-21-23),
I wanted to delete old station one day myself like Sat radio station numbers that moved, and could not figure it out either? Delete personal deletes all stored and input info like mpg, trips dest, and all other stored like Home. Not sure about Radio/Sat? I think I will try when I get a change. If you do it 1st let me know?
Okay, I finally wiped out my GS. That 'Delete Personal Data' is exactly the one I needed. It cleaned up the Nav addresses and radio info but none of the other settings and garage door still works. That one u have to hold the outside buttons on the mirror for 30+ secs to clear it up, it's not linked to the car's Nav system.
The stuff that got wiped out are:
- Bluetooth paired devices
- Phone stuff (phonebook, favorites, etc.)
- Radio presets
- Audio settings (Bass, Treble, Mid, etc.)
- Positions of audio device icons under 'Source' menu
- Navigation addresses, previous destinations, home and favorites
Other nav settings like traffic, MPG calculator, and trip info did not get reset, which is good. Upon reconnecting my phone to the nav system, there was an Enform update that popped up on the car's screen so I updated it. Not sure what got updated since the last time I did it but everything seems to be working fine. Things like Alexa, Yelp, iHeartRadio, etc all works. So it's all good to me and my radio presets are clean again.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
My battery died while I was re-entering addresses so I got to use the Amazon battery jumper that I got a while back and it worked and so easy to use.
When the battery was dying, the nav crapped out first, then the whole car started to fade out. It wouldn't even crank and just made a some weird and scary noises and the interior lights were flickering like crazy. Basically the whole car went nuts! lol
- Radio presets
- Radio presets
- Radio presets
Did you get my home address re-entered in your NAV?
![](https://i.ibb.co/47QYs1H/1-stop-smiley.gif)
No, this thing really died, the power seat didn't even move and the engine didn't crank. I know about the 15-20 min auto shutoff and this is different. I did get the low battery warning on the little screen by the tachometer a few minutes before it died, which is new and I've never seen that before in any cars I've owned.
The battery is 4 years old and I only drive the GS once a week for 2 hrs round trip so maybe the battery isn't getting the full charge like it used to pre-covid, when I drove it every day.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
RCF has been calling my name.
But I still like this GS.
bclexus (06-22-23)
