Change From C to F
6th Gear
I have a 2013 GS 350 purchased in Canada. I've moved to the US, and want to change the climate system from C to F units. But I can't seem to find a setting for this anywhere. Anyone know how to do this? Thx!
I don't think that is a programmable feature. I don't think Lexus allows that to be changed.
It's my understanding that there are other things dedicated to a vehicle that is delivered to a country that is to be used in that particular country - if allowed to be changed would not comply with that country's requirements, so none of them are allowed to be changed. You may want to confirm this with a few Lexus dealerships near the Canadian/U.S. border.
I don't know, Jamie. I can definitely understand why someone moving from Canada to the U.S. or vice-versa would want their controls to display correctly for their country's standards.
jgscott (09-08-23)
You can buy a used USA instrument cluster and have the mileage recoded. This guy can do it:
https://www.ebay.com/itm/233023074684
You can also ask if they can change your existing cluster from C to F.
6th Gear
I'm not familiar with Techstream.
@LxLuther - Unless you want to spend a few thousand CAN$ U.S dollars and a whole lot of time changing all sorts of things like the instrument cluster and control modules, I think it's probably best that you keep it as-is and just learn to deal with it...and hope it doesn't drive you absolutely bonkers!
![](https://i.ibb.co/84Zxmx0/1-crazy-smiley.gif)
As previously mentioned you would need the US spec body module to change the HVAC display to F. It should be under the dash, near your left leg. There's a few on ebay if you search for 2013 GS350 multiplex for $100-$200. Just swap it in and it should work.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
![](https://www.clublexus.com/forums/signaturepics/sigpic178522_1.gif)
262-456-4147
