Backup Camera not working after battery change
6th Gear
Hey..New to the forum.
I have a 2018 Lexus GS 350 F-SPORT.
Today i changed my battery at autozone.. Did not disconnect anything else but the battery.. After the change i noticed my backup camera is not working..
Also i have an aftermarket front camera from Beat Sonic thats also not working when i press the button.
Does it take time for the car to be off in order for the software for the camera to load up?
Is there somerhing i should be doing to remedy this?
Note i never had an issue with both cams and this was my first battery change on the car.
Have you tried disconnecting the battery again. And reconnecting, then pressing the start button (without pressing brake so engine doesn't start) and just letting it sit for a min or two, to let systems come up. Then starting the car?
6th Gear
it and it read rear camera disabled.....
anything else.can be done Or just take.it to the dealer?
6th Gear
6th Gear
6th Gear
The Beat Sonic system is causing the issue. There's a special procedure to reset it when the battery is disconnected. This affects both cameras since the rear camera plugs into the splitter for the front camera selector system.You can find the process on their website/instruction manual
0:44 in this video:
https://youtu.be/Q1PEXT_ogFE?si=VxnRpLoj6y7W9XuK
0:44 in this video:
gaki (09-21-23)
Maybe too late but thought I share. You should check the fuse for the camera system/navigation system. I installed an LED bulb for the license plate light and it shorted out the rear camera after a couple of months of use. Replacing the fuse and the light holder fixed the problem. System restarted and restored.
