Getting close to needing a set of Pirelli P7 AS Plus 3 Tires
#31
I have a set of these and let me tell you, I'd easily pay $100 more per tire. That's how much I like them. They're the quietest, smoothest tires I've ever had on any car, and they elevated my GS to a whole new level. I have 19" wheels for reference, and they are amazing.
I will say that due to the ride quality I REALLY had to watch my speed. 80 feels like 60, 100 feels like 80, etc.
Highly recommended.
Highly recommended.
#35
Not a surprise. Have had Pirelli All Season P7 (not the 3's) on several other Lexus vehicles (ES350 & Current 17 GS350 AWD) and they were really smooth 98% of the time, but both cars needed them road force balanced to make them 100% "totally smooth" at all speeds. Must somehow be the way they manufacture them as I hadn't ever had to roadforce balance any other tire brand over many years. In any case, you'll really like those tires once they are road forced !!
#36
I always have new tires Road Force Balanced by my local Discount Tire store and they are always perfect.
#37
#38
I got them today! ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I got a new set of 235/45R18 Pirelli P7 AS Plus 3 94V 70k mile Warranty tires (Item # 113768) put on my 2018 GS 450h at Discount Tire.
Road Force Balancing
Certificates for Damaged Tire Replacements
TPMS Valve Stem Kits
All four tires with same Mfg Date Code
Wheels remain at exact same location
Received $100 Special Instant Savings
Tire Pressure set at 38psi @ 72° - will be tweaked to meet my desired tire pressure.
#39
#40
Having had the Pirelli P7 AS Plus ll on my previous GS 350 I chose the Pirelli P7AS Plus 3 for another vehicle I own and I have been pleased with them on that vehicle, So, I decided to get a set for my GS 450h. I only have a few thousand miles on P7 AS Plus 3 tires on the GS 450h, but I'm liking them...
I think the Pirelli P Zero AS Plus 3 'NCS Elect' tire was not introduced or even available until late summer of 2023. I bought the P7 AS Plus 3 tires for the GS 450h on 1/31/2024 - - I don't think the Pirelli P Zero AS Plus 3 'NCS Elect' tire was even available at my local Discount Tire store then. If I had known they were a choice, I might have considered them.
The Pirelli P7AS Plus 3 is a very quiet tire. I'm a bit confused why Pirelli felt it was a good idea to introduce the P Zero Plus 3 'NCS Elect' tire. The former has a 70k mile warranty whereas the latter has a 50k mile warranty.
The Pirelli P Zero AS Plus 3 'NCS Elect' tire is tagged as a 'performance' tire, which I don't necessarily need on a Lexus GS 450h - and I rather doubt it's much of a 'performance' tire compared to some other available tires.
jgscott (08-04-24)
#41
If you want a very good (Michelin or better type), smooth, quite, great in rain, longer lasting tire and less expensive, get the P7 A/S Plus 3. If you want a tire that is more performance oriented that is the same plus, get the Yokohama Advan Sport A/S+. The Yok handles excellent and impressive and is going to last longer than all the other performance tires.
The P Zero AS 3 just is a bit better than the former P Zeros which all wore out super fast. There is already comments from some that used it longer term that it in fact wore extremely fast still. It's labeled as a "Ultra High performance" tire.
bclexus (08-04-24)
#42
The Pirelli P Zero AS Plus 3 'NCS Elect' tire was actually made for the carmaker LUCID.
The Pirelli P Zero AS Plus 3 'NCS Elect' tire has a treadwear rating of 560 - 600 with a 50,000 mile warranty.
The Pirelli P7AS Plus 3 tires that I have experience with has a treadwear rating of 700 - 740 with a 70,000 mile warranty.
I presume the Pirelli P Zero AS Plus 3 'NCS Elect' tire's lower treadwear rating and mileage warranty was a necessary outcome for the 'performance' tire rating.
#43
I've driven mother's cousin's 4GS in Paris with 96Y speed rating, and the Cinturato P7 Summers have nice soft 260 treadwear, but I can really feel the stiff carcass of the 96Y speed rating.
Your 94V will give you a beautiful ride.
I have an old 3ES with discontinued Bridgestone Turanza Serenity Plus tires with a hard 600 wear index, on juicy 205/65 R15 but only 94H speed rating to 210 kph metric, and despite the hard compound, the low speed rating with a flexible juicy sidewall still results in a very smooth and very quiet ride - though just me, but I am very sensitive, so I can still feel the harder compound being used!
Pirelli Cinturato P7 (tirerack.com)
Pirelli Cinturato P7 (P7C2) (tirerack.com)
Pirelli Cinturato P7 All Season (tirerack.com)
Pirelli P7 AS Plus 3 (tirerack.com)
#44
Are you using 235/45 R18 98Y with a UTQG wear rating of 560?
Tread wear rating of 560 will wear 5.6 times slower than tread wear rating of 100, hence a hard compound.
Worse is the 98Y 300 kph metric speed rating against comfort and quietness.
However, on the bright side, it should be very good at handling.
The harder compound is used to resist wear in cold weather.
The DWS06 is an ultra hi performance all season tire.
Continental ExtremeContact DWS 06 Plus (tirerack.com)
#45
Towards the end of tire life, all tread blocks become vertically thinner hence less absorbent and louder.
Tread wear rating of 560 will wear 5.6 times faster than tread wear rating of 100, hence a hard compound.
peteharvey (08-04-24)
