Panel under Speed Housing removal help?
Does anyone know how you remove this panel. Outlined in Red? It goes under the instrument glass over the the other side that has a blank square in it. Unless you have Night Vision or Hold there.
I was able to pop off the right side, but cannot get the left side pic'd. I don't want to break it. Anyone know? Seems I might to remove something to get it to come out? The Right side just popped right out with a plastic pry tool. Thanks.
All credit for the images below are from the famous @eddie420 post on the interior disassembly...i think you have to remove the upper leather trim part with the stitching that sits above the steering column first to get access since its a separate piece entirely:
https://www.clublexus.com/forums/gs-...l#post10329371
At very least, given that image that @AJLex19 , it would look like the trim piece you're trying to remove has a lip under the trim piece just to the left of it (with the BSM, Heater Steering, etc...) But there is that tiny lip that seems to go under that trim piece as well - but maybe as you pry it loose it'll come out just by pulling from the bottom.
jgscott (12-08-23)
Thank you both! @eddie420 great write up!
@AJLex19 I should have remembered that you are the Platinum 4th Gen info search MASTER. lol!
This is like the 1st time ever I could Not figure out how to get a piece off. Must be time for me to retire after this. I'm working on 2 projects with this.
1. Adding a Radar Detector Mute Momentary button in the Blank Tab, so I don't have to reach up over the detector mirror mount to mute the detector.
2. I have a 16+ Digital Instrument Cluster on the way, to see if I can get it to completely work and upgraded in my 13 Lux.
In case anyone else ever needs and finds this thread, here is also a link that shows some of those dash disassembly parts also I had found prior.
https://www.clublexus.com/forums/gs-...l#post11609583
Are you using custom buttons or are you going to use "Lexus"/OEM looking buttons for your two needs? As in, are you going to just drill the blanks and mount aftermarket buttons or are you going to repurpose some OEM buttons for your needs? If the latter, which buttons are you using?
Jakerin (12-12-23)
Hope I can figure out the Pin's to just use as a momentary switch as it's likely used for with the Brake hold. It will look more Factory reposing than adding a aftermarket button drilled in.
Here is a thread relevant to info on the Brake hold feature and that button switch also.
https://www.clublexus.com/forums/gs-...-retrofit.html
Were you confused about the pic in the 1st post with Red outlined? Do you know what now and clear and see it? Do you need anymore help understanding which part? After all that is the main point to understand what to be of help about, correct? My apologies for confusing one member.
Seems you have a real problem with this. Why..... idk????
bclexus (12-12-23)
How is this helpful?
