RCTA 2013 GS Brainstorming Ideas
10th Gear
I am creating this thread to brainstorm and figure out a way we can add RCTA to our 2013 GS models, I am sure it is possible, and I believe there is a module that would need to be added (possible plug and play) if the module is the same as the BSM module. I wouldn't be surprised if for the 2014 and newer models they made a BSM module that included RCTA (such as this: https://www.ebay.com/itm/175681303166?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=A33UTbhcSVu&sssrc=4429486&ssuid=4wn1TS66R-y&var=&widget_ver=artemis&media=COPY), if that is the case then the connecter may be slightly different and we will probably just need an adapter of some sort. Let's brainstorm and figure this out!
10th Gear
I have limited access to a 2014 GS350 parts car with BSM & parking sensors, my car is a 2013 GS350 Luxury package. I don't know if just because the 2014 has BSM & parking sensors it automatically has RCTA? Anyways I tried changing the parking sensor computer under the dash and I plugged in the 2014 front parking sensors to see if they would at least work they did not work. Any ideas on what the all that needs to be done or if we can just give power to the BSM when in reverse. What we would need to know is does the BSM operate the same when in RCTA mode as when in BSM mode? I'm sure we can figure this out.
jgscott (01-21-24)
I think you just need the new Cross sensors. But idk? Are the part #'s the same for the non cross as the cross ones are?
@peasodos Can you tell him how you did this?
I think @Chungvatra did a very nice build with this also on his 13.
@Xanomoros - I really like having RCTA. As soon as you put the car in reverse it senses movement to the sides of the vehicle's rear.
Many accidents happen when backing-up out of a parking space with cross traffic traveling behind you, so this feature is very worthwhile.
The RCTA radar sensors are installed on both sides of the vehicle near the rear bumper to detect vehicles approaching from the left side or right side of the vehicle's rear.
I think there are two RCTA sensors, one on each rear side located near the rear bumper.
Lexus Part# 88162-35010 I believe might be the correct module and it's cost is $1,000 retail and $700 discounted, but I think they are available on eBay, culled from wrecked vehicles for $175 to $500 each.
The alignment process is quite complex with the use of jigs and Techstream to get the angular alignment of the sensors within specs, as shown in the video in my next post.
I presume newer models of the Lexus GS might have the BSM module linked via harness to the two RCTA sensor/modules since RCTA is automatically activated whenever the BSM is turned On. But newer models of the GS have a much different and more elaborate instrumentation operation for various features compared to the early 4th Gen GS.
I cannot imagine adding and employing the RCTA feature in an early 4th Gen GS to engage and function like a newer model GS with the RCTA feature.
I hope this and the following posts (with videos) help you.
Hey Guys so let put some guidelines on WHAT I PLAN on doing YOU can do what you want to do as everybody has their own opinion and people like chiming in nonsense that has nothing to do with the OP's main objective of achieving RCTA in a 2013 Lexus GS350!
First I will try to focus the 2014-2015 model years for the RCTA as it is the closest to the 2013 GS350.
I have narrowed down to 2 part numbers for the Blind spot monitors both are used with the RCTA system, Also not every USDM Lexus GS350 that was equipped with blind spot and parking also had RCTA by default. second I'm looking up all the computer modules related to the RCTA & parking sensors and comparing them to the 2013 model year to get an idea of everything that needs to be swapped and what wires need to be rerouted or added.
having worked with similar systems before I can can tell you the Blind spot radars used for RCTA are omni directional vs the regular blind spot radars are just directional.
that is mainly the reason for all the extra computer modules. Honestly if going the oem route proves too much work I'm just going to get the radars mount them connect to a microcontroller and then the sky's the limit with that.
By the way Lexus Part# 88162-35010 is NOT the related to the Lexus GS350. Its for a Toyota 4Runner.
Please guys double check your numbers, sources and all information before posting as this is hard enough. Thank you.
Another U. S. short change example is the GS F. In Canada it comes loaded with Rear climate armrest controls, rear heated seats, power trunk, Rear sunshade, and more just like the GS350 Luxury package. The U.S. GS F got stripped of all those things, yet it was about a $90k stickered car.
https://www.clublexus.com/forums/bui...3-gs-base.html
Mods:
- 16+ rear cross traffic alert retrofit
BCLEXUS I wasn't aiming to discourage you from commenting. I'm sorry that I didn't paraphrase or structure my post correctly, the last thing I would want to do is hurt or wrong anybody especially a fellow Lexus Enthusiast. Please Accept my Apology.
My whole point was that a lot of times post's get misguided from the original purpose of the OP's objective with a lot of unrelated nonsense posts and I'm one of those folks that get easily distracted and that goes for everybody.
So Again Please Accept my Apology BCLEXUS.
bclexus (01-22-24)
10th Gear
