Going back to stock springs—need advice and parts
Old 02-18-24, 04:04 PM
  #106
Charlie777
Charlie777's Avatar
Originally Posted by fourgs
here are the pictures of manually turned dial. from factory it points to a yellow paint dot. I turned it towards driver. it just stays there.
So in the bottom pic, this is now manually set to the firmest position?
Old 02-18-24, 04:23 PM
  #107
fourgs
fourgs's Avatar
No its just proof of it holding the position that you set it.
the top picture is the default position. The default position is the firmest, its what car is programmed to when its set it for “17” . When car is parked its in firmest position.
Old 02-18-24, 05:29 PM
  #108
Charlie777
Charlie777's Avatar
Gotcha, this is why I’m confused about default being the most firm/stiffest position. The stiffest position “should” be when that adjustment piece is parallel with the flat spots on the strut (Position C) but in your pic, it’s definitely in the position (Position B) which would be the Medium or Center position.
Old 02-18-24, 06:36 PM
  #109
fourgs
fourgs's Avatar
When taking off the actuator from shock you turn it to remove. It probably moves the dial when turning it.
Old 02-18-24, 06:40 PM
  #110
fourgs
fourgs's Avatar
Any way seems that active manual control for full firm is not possible when driving. Since the dial will just remain where it was if you disconnect the fuse when you drive.
it will remain in position 5 if in normal, position 11 if in sport +, and full firm 17 if car parked.
Old 02-19-24, 06:27 AM
  #111
jsbach1685
jsbach1685's Avatar
also did driving with live data opened on techstream. car by default is always in firmest position. when off, when parked running, and when in drive but not moving, when you start driving above couple of miles it switches immediately to 5 on my car and in sport plus it swithces to 11 front 7 rear.
also filmed a video of the actuator when its removed ,
heres the actuator video. trigered by techstream to goo all positions.https://youtu.be/u3-dsp3wMmY
fourgs,
So for your 17 f sport awd, techstream confirms 11 front and 7 rear when in sport +. Question: Do you know anyone nearby (or even any for sale) 13-15 f sports that you would be able to verify with techstream any drive-mode parameter differences between the 4gs and 4.5gs. I have an 18 f sport awd, so I would assume our parameter figures (11F / 7R) would be the same in sport +. I have a feeling the 13-15 f sports have higher figures.
Old 02-19-24, 03:35 PM
  #112
fourgs
fourgs's Avatar
I dont know anyone nearby with a gs. If the avs module (on lexus parts online for example) has part number that is different than probably it had different tuning.
Old 02-19-24, 04:19 PM
  #113
peteharvey
peteharvey's Avatar
Originally Posted by jsbach1685
fourgs,
Yes, it would be interesting if the software mapping for the shock absorber valves is the same or different of the original 2013-15 and the facelifted 2016-20's.
Old 02-21-24, 09:40 PM
  #114
EAST
EAST's Avatar
also did driving with live data opened on techstream. car by default is always in firmest position. when off, when parked running, and when in drive but not moving, when you start driving above couple of miles it switches immediately to 5 on my car and in sport plus it swithces to 11 front 7 rear....
You made me curious, and I took some measurements while doing an errand. My numbers are a little different than yours.
I have an 18 RWD.
Anything not Sport +: Once driving, it would mostly chill at 3 in all four corners. If I swerved back and forth within my lane, it would go up to 5, and sometimes 7 when taking a corner, but would try to default back to 3 when possible.
Sport +: It would default to 7 in front and 3 in rear. Any swerving within the lane would go through all the positions, up to 17.
I did a data log, but can't find a way to get the data to play out.
The following 2 users liked this post by EAST:
GrandSedanFan (05-21-24), peteharvey (02-21-24)
Old 02-22-24, 05:27 AM
  #115
fourgs
fourgs's Avatar
I have an 18 RWD.
was driving in parking lot. Dont know about higher speeds. Is your luxury or f sport? Maybe it adapts to driver history also like the transmition
Old 02-22-24, 05:53 AM
  #116
EAST
EAST's Avatar
RWD FSport.
I have to get a better recording with the right parameters.
Yea that's a possibility about the historical values. I forgot to mention, this with an obd2 scanner. At least on my old laptop techstream updates like once ever few seconds, so data captures aren't as informative.
To me the more surprising was that it still did some dampening in nonSport plus mode.
Old 02-22-24, 05:55 AM
  #117
jsbach1685
jsbach1685's Avatar
That would be my first question too... Is EAST's 2018 RWD a Luxury or F-Sport? Btw, is Techstream a hardware device (i.e. factory scan tool) or a software program that can be used on any computer or tablet (i.e. iPad)? Regarding drive-mode software mapping, I guess I could inquire with my Lexus dealer and see if there are any technicians that have any knowledge of this? God knows I've spent enough $$$ there with all this suspension stuff. Is "Software Mapping" the correct terminology? Or perhaps "Drive Mode Programming." Do you know who I would love to ask: The Car Care Nut.
On another note, I continue to slowly get acclimated to stock suspension again. I'll probably never get used to the look--especially it being an AWD. I could probably deal with the stance of RWD.
I'd love to see what numbers show up on Techstream for my car. It should be the same as fourgs, but who the hell knows...
Old 02-22-24, 10:54 AM
  #118
EAST
EAST's Avatar
Techstream is the software. Officially, you can get it from Toyota as a subscription (yearly or 2day pass, I believe).
The hardware is an OBD2 to USB cable. There are a lot of clones of a Mongoose cable online. There's particular firmware versions that work with the newer cars. I know mine required me to run a VM to run Win XP because of the drivers. But I saw another thread elsewhere where someone got the driver's working on later versions of Windows. Or you can get the "actual" cable as well, likely less hassle.
Since it's USB, I don't see why you can't run on a Windows tablet with USB support.
Old 02-22-24, 10:58 AM
  #119
kietlander
kietlander's Avatar
Update (#3)
I finally got around to pulling the fuse to deactivate the AVS system. My
brother and I took a drive for about 50 miles. Holy crap!
If you want your GS to drive like a go-kart, then this is the setting for you. It is super firm and you feel everything. And I’m back with stock springs. I couldn’t imagine what it would’ve been like with the Swifts. It seriously felt like the car was half its size (vs. driving a boat). I wonder if this can be turned on/off while the car is on? I would run wires from the fuse box position, incorporate the fuse and an on/off toggle switch. Then you have 4 modes: Eco, Sport, Sport+ and KB (Kidney Buster). Lol…
why pull the fuse, couldn't you just unplug the connector at the actuator?
Old 02-22-24, 10:59 AM
  #120
Lanson
Lanson's Avatar
I would also be curious if the system compensates over time for wearing parts, through the feedback loops involved. Example, car in a hard sweeping corner receives pitch, yaw, roll, and heave inputs. As parts break in and later wear, they will be more compliant. This is similar to how throttle bodies have a baseline % opening and a learned one, I would think. It's all fascinating and I want to comment that this thread has been a huge on information, and clarified a lot of assumptions so thanks for that.
Quick Reply: Going back to stock springs—need advice and parts
