No climate control in the back seat
The back seat zone of my 2013 GS350 is cold during the winter and hot during the summer. A few days ago, it was cold outside. The front seats got lots of heat, but the air blowing back from the center console was icy cold. I think it only delivers outside air.
Does anyone know how to fix this?
I checked. Three zone mode is on.
I cranked up the temperature to 85°F and maxed out the fan speed. There was a trickle of warm air coming out the vent.
If I have it in face-only with 3-zone off I get tons of flow from the vents.
What do you get?
Search Lexus Customer support SERVO problem. a/c should not being coming out other vents when heat is on.
The following 2 users liked this post by CottageChz:
Im2bz2p345 (01-10-24),
Mangsailor (01-10-24)
Mangsailor (01-11-24),
tompass (01-11-24)
My last suggestion to him was to change the modes to full-face, which should give him more flow to the back.
If that works, then it means everything is working hunky dunky.
Yes I think the op needs to clear up some details of exactly what is going on, and what setting are doing what? I still say Servo, because it's a known problem. It has the problems, that have the vents blow cold when you have heat on, and Heat when you have a/c cool on.
The Blend doors are controlled by the Servo motors. If they are malfunctioning they can - Be in a position to blow different for that vent. They also can malfunction and stay open when they should be closed, or closed when they should be open. That's why I think it Servo's. But.... maybe I am confused about what is actually happening, where, and when?
Does he have a Lux with 3 way? Climate in Rear seats Armrest?
https://www.clublexus.com/forums/gs-...s-it-work.html
https://www.clublexus.com/forums/gs-...low-issue.html
Manual's explanation:
When the S-FLOW switch is pressed,
the airflow changes as follows.
Without rear air conditioning system:
Air flows to the front seats only.
With rear air conditioning system: Air
flows to the front seats only, and if the
passenger seat is unoccupied, the set
temperature, outside humidity and
temperature inside the cabin are
assessed, and air flows to the driver
seat only.
seat only.
