Battery Replacement, Infotainment Reboot and Battery Settings Saver
Please don't flame me for asking this! I have searched and cannot find the post that I remember seeing a while back..
Several questions:
Thanks in advance.
Several questions:
- Do I need to use a settings savers when replacing my battery? If so, what style should i get? OBD vs cigarette lighter style vs using jumper cables.
- Does the setting saver eliminate the possibility of an infotainment failure upon restart?
- What is the startup sequence to help ensure a successful infotainment reboot? I remember reading a post describing the process but cannot find it.
Thanks in advance.
I just reconnected my battery after a day if having it reconnected.
All I can really comment is in point 3.
I had the key inside the car (on top of the center console if it matters). I connected the positive terminal. I left it sit for a minute.
I pushed the Start button once. I let it sit for a few minutes. During that time, the infotainment screen said something about starting up and to not power off. I waited until it was done and on the caution screen. My guess is here is where bricking could occur.
I pushed the start button again. The console lit up like normal. I let it sit for a minute or so. Then I started the car.
@jsant1070 No need to use a settings saver. I didn't use one and had no issues with my infotainment/head unit afterward. Since you've changed many batteries in the past, its not much different just be patient with it.
See my post here for additional tips: https://www.clublexus.com/forums/gs-...l#post11044612
jgscott (01-28-24)
I actually replaced my Optima Red Top battery today after just 2yrs 10months. It was still under the 3yr warranty offered by Optima/Autozone. Third time this month I had to jump it to get the GS started.
The in-store employee correctly said my original purchase was made on Autozone.com on 3/21/2021 and I should contact cust service 800 # to get more info since the battery is not stocked at any brick/mortar Autozone.
Customer service then said this should all be handled in-store - they would be able to either replace with an equivalent "Duralast"/Autozone branded battery if they didn't have the same one in stock. Went back in-store and I spoke to the manager - said since they don't have the same battery in stock, they could only offer me an upgraded battery in-stock battery (Optima Yellow Top) and I could pay the difference. I explained I was willing to accept a cheaper in-stock Duralast battery, but he kept insisting showing me his computer wouldn't allow him to do it (how convenient right?).
After spending way too much time on the back-forth, I paid the small difference and got a fresh battery. Followed the standard DIY procedure - but the yellow top required me to remove the OEM plastic battery cage entirely. Even though they looked very similar in overall dimensions, the terminals on the yellow top were closer to the middle instead of toward the outer edges making the connection tougher.
Takeaways:
-Maybe its just me, but I would not recommend the Optima brand. It lasted the shortest amt of time for any battery I've ever owned.
-Autozone's policies are terrible for batteries purchased online that aren't stocked in store. Employees were patient and willing to assist, but the inconsistent answers between phone support/in-person was mind boggling.
-If I had a trustworthy Lexus dealership nearby, i'd likely let the dealer handle replacement using an OEM battery. I only went the Autozone route bc I was still under the warranty period.
Takeaways:
