Headlight height adjusting on 2019 GS F Sport
2nd gear
I have come across quite a few topics about upgrading to triple beams, but not adjusting the beam height on the stock lights. Can somebody share how to raise the beam on a 2019 GS F Sport? I can't see more than 1 second in front of the car at night when doing 60 mph. High beam are great!
I purchased the car in Dec that replaced a 2001 GS 300 with over 328K miles on it. I am hoping this car is as good as the last Lexus.
Welcome! Check out this video to adjust your lights. The procedure is very similar to the GS-F in the video. I did the same on my 2020.
mjo13 (01-26-24)
2nd gear
BlueIS05, Thank you for pointing me in the correct direction. I feel rather naive as I watched the video prior to posting but was looking strait down the holes in the plastic cover rather that at an angle.
I need to play around more as I adjusted the height with the lights on, car off. When I started the car the lights adjusted down. I put tape on a wall to know my starting point. More adjustments to come.
Also the full moon did not help with test driving. Initially I thought the projection of the lights was great until I realized the moon was helping light everything.
So you adjusted them up with the car off, and when you turn on the car, they adjust down? If so, then your height sensor(s) may be causing issues with the auto leveling of the lights.
Lfig402
12-27-21 02:15 PM
