AWD: must replace all tires together ?
2nd gear
I have a '15 GS 350 AWD. My front tires are still pretty good, only about halfway worn, still drive just fine. Can I replace just the two back tires without having to do all 4 at once ? I've been seeing different things about this issue. Some say you MUST replace all 4 tires at once on AWD cars. Seems like a sales gimmick to vastly boost tire sales. I've read that you're supposed to check the manual on this, but I checked and couldn't find anything. Does anyone know for sure the answer ?
Welcome! I think it really depends on the tread depth. If your front tires are at 4/32" or 5/32" and the new rear tires will be the same brand/make/model tires at 10/32" or 11/32", I would replace all.
You want to keep the overall diameter as close as possible for your AWD. The wider the gap in tread depth between current tires and new ones you plan to mix, the more likely you should replace all. See this helpful thread and some good responses/links: https://www.clublexus.com/forums/gs-...wd-system.html
NJLEXES (05-14-24)
2nd gear
Lanson (05-17-24)
