Evaporator Purge Vale
The purge valve is located in the vacuum line between the fuel vapor containment canister and the intake manifold.
If you think it is a problem for some reason, it might not be as they rarely fail... More often than not, the problem is it gets flooded with fuel by overfilling the fuel tank.
These images (below) I've included should help you find where the evaporator purge valve is located.
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/616x587/screenshot_2024_07_15_065101_6b463a73825922386f10ed685aebae345e4049da.png)
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/304x197/screenshot_2024_07_15_065314_017a64e982b93d8f7214b228af2b460ea56f4c4b.png)
![](https://i.ebayimg.com/images/g/egIAAOSwBGRioSq~/s-l500.webp)
