Pulling to the right after alignment?
I’ve already read a couple threads that have addressed a pull after an alignment but this one’s got me kind of stumped.
Just picked up the car 3 weeks ago from a dealer and noted a pull during the test drive. They agreed to fix it as part of the sale. An alignment was done when they got it but I asked for another. They did it again and got it dialed. Still pulling. Another thing they’re fixing as part of the sale is the back left BSM sensor needs calibrating and they think that could be the reason for the pull. Idk, I’ll find out tomorrow when it goes back in for service. I’m also hearing a howl that sounds like a wheel bearing along with a slight pulsing vibration, but they said they heard nothing through the stethoscope. If that’s not it, all I can think is it needs new tires. I’m at a loss. Don’t know why it’s pulling and don’t know where the howl/pulsing is coming from. Wheel turns almost immediately when letting off the brake from a stop. Is this some sort of electronic steering calibration issue?
Is it pulling to the right or the steering wheel not directly straight on when the car is tracking straight?
It could be road camber. Drive the car at freeway speeds and see if the car drives straight for 3-4 seconds. If it does then it more likely the steering and you need to adjust the tie rods to get the steering wheel straight
BSM sensor is blind spot monitoring. Tires aren’t new but they’re not showing extreme or unusual wear. And this is a Toyota dealer.
The wheel is center when keeping the car moving straight and alignment is pretty dead nuts. It actually pulls to the right immediately after letting go of the wheel.
Yes there is a Yaw and Rake steering calibration done in Techstream. But I don't think it's your problem if it's pulling like you say.
Sounds like maybe wheel bearings, and/or some other steering or suspension parts worn on gone bad. One other thing is the brakes if they are hanging up on that side some.
Jewbacca92 (09-16-24)
It just seems weird to me that the blond spot monitor radar would influence steering. I could see the sensors that jgscott mentioned but not BSM.
Then again it's at least a Toyota dealer, so they should figure it out.
They’re also “fixing it as part of the sale”, which really means any repairs have to be approved by sales. If it’s too expensive, there’s a chance they could deny responsibility. Hopefully the fidelity warranty I bought will cover it. If not, worst case is they’re able to diagnose it and I’ll do the work myself.
Update:
BSM sensor is calibrated and car is still pulling. Service department literally asked if they could install the GS-F LCA bushings i have in my back seat free of charge to see if that fixes it. Of course I said yes. Even if it doesn’t fix the pull, it’s free labor! I never thought a dealer would install customer provided parts that aren’t specific to my model.
More updates to come.
That car may have hit a curb or pothole hard enough to bend/damage a suspension arm or part that makes the car pull to the right. It might not be visually apparent or even noticeable when an alignment is done.
Control Arms: The control arms are connected directly to your wheels, making them particularly vulnerable to an impact. Damage can cause misalignment, loose steering, and uneven tire wear.
Tie Rods: Tie rods can get bent if you hit a curb, causing your car to misalign and create uneven tire wear. As a result, you may feel the car pull to one side.
tompass2 (09-20-24)
Just picked the car up after they told me installing the LCA bushings fixed it. It most certainly didn’t.
They also messed my bumper up while fixing a rear sensor. Looks like they couldn’t align it right, tried to force it, scratched it up, then gave it back to me with bulging panel gaps.
Whoever is working on my car clearly has no idea what they’re doing and doesn’t care.
