4th Gen GS Aftermarket Wheel Thread
#662
#663
they're called puddle lights. I follow a shop on Instagram under the name tnautoinspired . Since you're in SoCal try reaching out to them and ask them if they sell it. I know they do installs of the lights.
#664
ill be sure to put up pix when completed.
#665
I have tried them all trial and error. Without a fender roll, 245/35/20 +35 on a 9 or 8.5 is the correct for the front. 255 will rub regardless of the wheel.
For the back 275/30/20 +45 on a 10 or 10.5 is correct and the largest you can go. 285's will rub. Note: 10.5 on back will give you a bit of a lip on your wheel. If you dont like that look you will need to size down the wheel to a 10. 9.5 is OK too, but if your wheels are concave you will lose some of the look. If not it won't matter.
I am running 9's and 10.5's on my 13. 245/35/20 and 275/30's.
Front 20 x 8.5 offset 32, 245/35/20
Rear 20 x 9.5 offset 36, 275/30/20
Will this rub as i do not intend to lower the car.
#667
Love the stance and wheels on this badboy. You are also one of the few I've seen here with AWD and a drop and what I am planning to do with my 2015 as well. Can you share with us what setup you are running, springs? spacers? camber offset? any issues? How long have you being riding in this and how the ride quality vs 19" oem non-staggered. Thanks dude!
#668
Hey Guys I am looking to get some rims on a 15' Fsport RWD. The rims specs I am looking at are F: 20x9 +35 and R: 20x10.5 +40 will this give me a flush or slight poke look? I the flush/slight poke look. I also like the meaty tire look and was hoping you guys can give me some advice. The tire sizes I am thinking of is F: 245/35/20 and R: 275/30/20. Are these tire sizes the meatiest I can go without rubbing? I am also going to be lowered on Swift Springs. Thanks!
#672
Originally Posted by tirehookup
My Turn!
STR 524 Neon Blue
20x10 (F&R)
245/35/20
275/30/20
Tanabe Springs- No Rub, No Roll
STR 524 Neon Blue
20x10 (F&R)
245/35/20
275/30/20
