4th Gen GS Aftermarket Wheel Thread
#932
#933
I have 285s on a 10.5" wheel and looks a little stretched which bugs me a tiny bit.
The bulge looks aggressive and from the pics, like it is hella flush with the fender. Hehehe
#934
How much camber are you running with 305's?
#935
factory specs, just dropped with RCF swift springs.
275/30s installed up front on 20x9+30. Had to bend all the liner tabs up, pull the 10mm bolt and replace with clip, and grind down the bumper/fender mount a few MM. after that only slight rubbing on hard dips or dips/bumps with wheel turned. All in all took about 30 min and happy with the fitment. Excited to run 305/275 stagger.
#936
^^^I'm now convinced GS-F have way different rear factory suspension geometry's than regular GS's.
No way a 305 on a x10 et40 would fit in the back of the GS with factory camber.
#937
If I have a 20x10.5 et30 and 285s that don't rub on a 2013, wouldn't a 20x10 et40 with 305s be pretty close?
#938
#939
I am finally about to order my wheels this week. 285-30-20 20×10.5 et45 and front 245-35-20 20×9 et ?.
I would like to know what offset i should go with if i want to clear the fender and the caliper? 30 or 35 offset?
#940
Also posted on: https://www.clublexus.com/forums/gs-...-sport-gs.html
Thought it might get more traction here.
What do you guys think? They are 2011 Mustang GT Track Pack 19x9 + 42 offset wheels with 255/40/19s? Think they'll fit without rubbing? If need be I could get some 235 or 245/40/19 for them? I got the idea from: https://www.clublexus.com/forums/gs-...-my-gs300.html
Need to find some hub centric rings 70.5mm to 60.1mm which is proving harder than I thought.
GS350BEN (08-07-21)
#943
1st pic:
Leon Hardiritt Bugel 19x9+15 19x10+20
225/35 front and 245/35 rear
2ndpic:
TSW Bathurst 20x9+30 20x10+40
235/35 front and 275/30 rear
On Airlift 3P. Stock Arms. Currently running the TSWs. Shaved rear fender lip for clearance
GS350BEN (08-07-21)
#944
For those of you who are running 235/35/20 in the front, what tire load rating do you have and brand of tire? In Canada, the highest rating I can find is a 92Y which for the Pilot Sport 4s's or A/S 3+ however I'm worried about the weight of the car since the OEM AWD F sport tires specs are 235/40/10 96V XL.
#945
