4th Gen GS Aftermarket Wheel Thread
Old 06-23-21 | 09:00 AM
  #991
mfaheem's Avatar
mfaheem
Has anyone ever run 255/40/19 for the front ? I'm looking for that tire size for my ISF wheel ET 55 but adding a 10mm HR spacers
Old 06-24-21 | 07:08 AM
  #992
np20412's Avatar
np20412
​​​​​​​I'm pretty sure 255 even on the stock 19x8 +45 will rub, so I would go ahead and surmise that with a 255 on the ISF 19" wheel effectively made to +45 by your spacer will also rub.
Old 06-24-21 | 07:10 AM
  #993
mfaheem's Avatar
mfaheem
Interesting but the GSF stock wheel is 19x9 ET 50 mm stock in the front and comes with 255/35/19.
Old 06-24-21 | 08:15 AM
  #994
np20412's Avatar
np20412
If not lowered I guess it might be ok. Isn't the ISF wheel 19x7.5"? If so, that helps.
https://www.clublexus.com/forums/gs-...l#post10497502
Old 06-24-21 | 08:18 AM
  #995
mfaheem's Avatar
mfaheem
No the isf wheel that I plan on using is 19x9 55 mm but I'll be adding a 10 mm spacer. Was torn wether to order 245/40/19 tires or 255/40/19. I'm sure 155/35/19 would fit but I want bigger sidewall for NJ roads
Old 06-25-21 | 05:42 AM
  #996
RaiderRick's Avatar
RaiderRick
Newbie question. Will be pulling the trigger on ADV1 ADV5.0. Not going to lower the car fora while. Just checking if i’m going to have any rubbing issues. And also which is the best tire to get for daily comfort drivimg. Thanks
20x9 +35 245/35/20f
20x10.5 +45 275/30/20r
Old 06-25-21 | 06:48 AM
  #997
thisguy_06's Avatar
thisguy_06
20x9 +35 245/35/20f
That's an extremely common size/specs; you'll be fine.
RaiderRick (06-25-21)
Old 07-05-21 | 12:24 AM
  #998
Clyde90303's Avatar
Clyde90303
Last edited by Clyde90303; 07-05-21 at 12:27 AM. Reason: Delete please, I forgot to tag the person I was replying to.
Old 07-05-21 | 12:26 AM
  #999
Clyde90303's Avatar
Clyde90303
Originally Posted by 00goobs
Oh my, I haven't seen this color in person!
Looks beautiful!
Did you black.out the trim around the windows?
Thanks bro, I had to do something different to stand out. It's not the best job in person but yes, I ended up wrapping the trim myself. Now I'm just debating on wrapping the front and back pieces.
Old 07-09-21 | 04:41 PM
  #1000
np20412's Avatar
np20412
Happy 35th birthday to me. Had a blowout a few weeks ago figured it was a good excuse for new shoes. I wanted something to break up my black/white theme and I always loved the look of bronze/gold on white. Fitment is good, no rubbing as the tires seem to run skinny and i picked a skinny front tire but did end up with a slight 7-8mm poke on each wheel instead of being flush since I wanted a solid concave in the front too. Front tires are stretched a decent bit and rears have a very mild stretch. I wanted the Vossen CV3-R but they had a 2 month lead time AND they jacked up the price of that set, which would have sat flush. Even though they're 20s I feel like they look like 19s on account of the black lip, but I like it. Overall I'm pretty pleased with the look and stance.
Ferrada FR-3 (deep concave) bronze w/ gloss black lip
20X9 +25 (225/35/20 - I think a 235 will work so I'll up size next time around)
20X10.5 +38 (275/30/20)
The following 5 users liked this post by np20412:
FullMetalM (02-14-24), kjk944 (08-03-21), Kroaker (07-17-21), Speedkrazy (08-02-21), UpstateLex (07-17-21)
Old 07-10-21 | 12:32 AM
  #1001
KVelasqu3z's Avatar
KVelasqu3z
Need some help. I recently just purchased the Forged Aluminum F Sport rims. I know it’s really not considered aftermarket but I was wondering if you can help me. I’m currently lowered with Coilovers. It has +40mm offset will I be ok with 245/40/19 front and 275/35/19 rear? I’m about 1” above tires right now. Also I ordered 15mm & 20mm spacers that are coming in next month. Would I be able to use them with these rims?
Old 07-11-21 | 08:55 AM
  #1002
jgscott's Avatar
jgscott
Did you ever put the 245/40/19 on yet? Or has anyone else run the 245/40/19 on their GS?
Old 07-11-21 | 11:34 AM
  #1003
np20412's Avatar
np20412
245/40/19 is a very common up size from the 235/40 that comes stock on the 19s. Shouldn't be any problem.
Old 07-15-21 | 10:03 PM
  #1004
1LOWG's Avatar
1LOWG
Will this set up work on a bagged GS?
size................F: 20x9” R: 20x10”
offset.............+36mm F+R
tire size..........F:235/35/20 R:255/35/20
Old 08-01-21 | 11:21 AM
  #1005
Bodazeffa1's Avatar
Bodazeffa1
Default My 2017 gs350
Wanted some opinions on the look..
