F-Sport vs AWD differences
Maybe someone can clarify, adding AWD to F-Sport cost more money but they take away variable gear steering and 4 piece calipers / cross drilled rotors & staggered wheels. So do you sacrifice better handling when adding AWD? AWD should be a no cost option on F-Sport since you don't get the above mentioned you are essentially paying for more but getting less.
Well the awd fsport steering and 4 piston caliper is the same as the rwd but not a 2 piece floating rotors the rwd also dont have cross drilled rotors but have the 2 piece floatig rotors. wheels are the same but the rwd have fatter tires on the rear. Honestly i have the awd and thats **** handle Amazing, as is i just say the rwd would be more fun to drive. Only reason i got the awd is becuase we have some crazy winter over in canada but it does drink abit more gas then the rwd. Hope they clear up some stuff for you .
awd, caliper, difference, differences, drive, fsport, gs, lexus, lexusfsport, rear, rx, sport, versus, wheel
