Auto-tilting side mirrors in reverse
If I remember correctly, while the car is in reverse, you can set the degree and placement of where you want your mirrors to be. After you adjust them, they will go back to that spot every time you reverse (granted you leave the mirror adjuster light on either the left or right mirror).
In the past, everytime I put the car in reverse, both the left and right rear vision wing mirrors dip.
However, lately it no longer auto-dips.
So I pressed one of the left or right rear wing mirror buttons, and made sure that the green light lit up, and the rear wings mirrors certainly auto-dip.
However, here is my problem.
After I turn the engine off, and then restart the engine - that left or right green light is no longer on, and the rear wing mirrors no longer auto-dip.
So all of a sudden, after I start the engine, I must manually press the left or right rear wing mirror buttons to turn the green LED's back on, if I want the wing mirrors to auto-dip; yet I never had to do this manually after each engine startup in the past.
NB. I have not readjusted the seat nor steering wheel at all.
Does anyone know what is going wrong?
Or is there an adjustment for this so that the green wing mirror LED's actually "stay on", like it originally did???
Should I bring the car back to the dealer?
Both my mirrors tilt down when I switch to reverse
Alright here u go folks ..
U start the engine
Put it on reverse
Select from ur door panels the side mirror u wanna adjust
Move the side mirror to the point u want using the arrows
And thats it
When u put it into drive. The mirror will go back to the original setup
And when u put it on reverse ur mirrors will till
U start the engine
Put it on reverse
And thats it
So if u r on preset 1 seat position, put into reverse, do the adjustments to ur liking, put back to P, press SET then press 1. Viola!
So if u have the 2nd driver on preset 2 he or she can preset his or her angle of tilt of his or her choice. All he or she needs to do is to do the above adjustments on preset 2. Simple!
& on top of that, u can save ur adjustments juz the way u save ur seat adjustments! Didn't u guys know that? So all together u can save up to 3 different tilting settings. So if u r on preset 1 seat position, put into reverse, do the adjustments to ur liking, put back to P, press SET then press 1. Viola! So if u have the 2nd driver on preset 2 he or she can preset his or her angle of tilt of his or her choice. All he or she needs to do is to do the above adjustments on preset 2. Simple!
U start the engine
Put it on reverse
And thats it
U start the engine
Put it on reverse
And thats it
From what I have noticed on mine, the mirrors (both) tilt downard when I put the car into reverse. I do not see any outward tilt or shift. When I cancel the left or right mirror and put it into reverse, the mirrors do not move. Not sure why yours is tilting out first then down unless there is a way to set it that way.
another thing i am puzzled. seems like selecting the the left or the right mirror dont make any difference to the way it tilt? is this true or i am not observant?
there seems to be lots of other features that i am still not aware of. the button next to the rear sunshade up/down switch is actually the on/off switch for the front/back sensor!!! i just realized that today coz i have some how off it a week ago and scratching my head why my front and back sensors are not working!!! it helps as there is lots of narrow spiral multistory car park here.
