TPMS Display
Old 04-03-12, 03:06 PM
MikeP
MikeP's Avatar
Default TPMS Display
I'm curious if Lexus identifies the tire position now as it displays the tire pressure on the 4GS. Only the tire pressure is displayed in my '10 LS.
Old 04-03-12, 03:14 PM
HUSKERnKS
HUSKERnKS's Avatar
What exactly do you mean by tire position?
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
YES...
.. It now does in the 2013 GS ....
Joe Z
Old 04-03-12, 03:15 PM
crzyis
crzyis's Avatar
Yes it does
Old 04-03-12, 03:19 PM
Room4Tu
Room4Tu's Avatar
Please explain more. What is this tire position? Is this related to alighment of the wheels?
Old 04-03-12, 03:20 PM
HUSKERnKS
HUSKERnKS's Avatar
Default Pic
Here is what it looks like.
Old 04-03-12, 03:28 PM
Room4Tu
Room4Tu's Avatar
Attachment 241804
Thank you. This pic is worth a thousand words.
Old 04-03-12, 05:39 PM
MikeP
MikeP's Avatar
EXCELLENT
Old 04-03-12, 06:02 PM
Rexus300
Rexus300's Avatar
Husker,
My GS F-Sport felt a bit choppy at highway speeds with those high tire pressure which was recommended. I decreased it to 33/33 F/R and its much more planted and smoother with great road feel in normal and Sport + mode. Otherwise that pressure you are using is only if you have 4-5 people including cargo with speeds greater than 100 mph.
Old 04-03-12, 06:10 PM
HUSKERnKS
HUSKERnKS's Avatar
Interesting....
That's how the dealer set it. Did you have to reset your TPMS? How do you do that?
Thanks for the tip!
Old 04-03-12, 06:16 PM
Rexus300
Rexus300's Avatar
The great thing about this TPMS is that no beeping at that pressure until around 28 psi. The dealers are now putting pressure down for customers given the firmer bridgestone turanza tires so it is very nice at 33 PSI all around cold. No choppiness on all kinds of highways and grooved roads. There is some flat spotting with these tires just like any low profile ones but very minor when sitting overnight. No reset needed unless changing the wheels.
Old 04-03-12, 06:19 PM
HUSKERnKS
HUSKERnKS's Avatar
I have the Dunlop SP Sport 5100 A/S. Does that change your recommendation?
Old 04-03-12, 06:20 PM
mehran888
mehran888's Avatar
Hey guys, just a note that in Canada, only the Luxury and Technology packages display the TPMS for each wheel.
As far as I know, the base, Nav, and F-Sport packages only have a "low tire pressure" warning, but no location.
I imagine the US may be similar.
EDIT: For those outside of Canada with different packages, I'm presuming that if you have anything above the "regular Nav" package (aside from F-Sport) you probably get this. So if you have any of rear climate control, wood trim, ML, blind spot warning, HUD, etc.
Old 04-03-12, 06:23 PM
HUSKERnKS
HUSKERnKS's Avatar
I have premium package plus other options (nav, blind spot, park assist, cold weather, etc).
Mine shows all 4
Old 04-03-12, 06:59 PM
Rexus300
Rexus300's Avatar
Even on premium package, the tire pressure is way too high. 33 F/R is still recommended for you with the Dunlops.
Quick Reply: TPMS Display
