Update on Auto AC Problem
#31
I did check the part number from Sewell then it come up with this:
For luxury model with seat heater: 88650-30P70
For other model: 88650-30P60
They replace mine with 88650-30S60 which seem odd.
4GS owner had AC amplifier replaced please confirm part # and option on your car?
#33
I had the same issue after replacing my LS460L cabin air filter.
As soon as you start the car, AUTO light would come on but no lights on recirc/auto/fresh air button. And the fan would not run and no driver/passenger temp display either. Looked like the whole climate control system was in a shutdown mode. After 15 seconds or so, climate control would come on resetted to 75 degrees and would forget my previous settings when I stopped the car. It was very easily reproduceable every time after I shut down and locked the car.
I had not broken the recirc/fresh door infront of the filter as I was very particular about it and read all the instructions before replacing the filter.
My fix was to take the filter out of its plastic casing and re-install it with "TOYOTA" "MADE IN USA" and "UP" printed on the filter to face the rear side of casing. Before it was towards the front side of casing. I had noticed it when I took the previous original filter out but did not think it would matter which way the filter goes as long as "UP" is actually pointing "UP".
Ironically the car has some sensitive sensors that detect may be the filter is not there I think. I re-installed it correctly and seated it above the blower pressing all four sides. Need skinny hands to get in the back of it. Since then its fixed and climate control works normally as before.
