First off, I absolutely love the size of the nav screen in my new GS. I am trying to figure a couple things out, and I have looked through the 3,000,000 page manual for the navigation with no luck :-(
1. The screen is huge, we all agree. However, when you have the split for the stereo/climate, and the exit popups when traveling on the FWY, it makes the map like 3 inches wide. Is there a way to turn off the popups for FWY exits?
2. Can you turn off the split screen so you can see the map on all 12.3 inches of the screen?
You can turn off the exits when on the freeway. I think it's under map mode...as for the full screen, I believe it is not possible. Others can chime in if I'm wrong.
I think the screen is too wide and short to display a DVD correctly, so you would end up with black bars on the sides anyway, which is basically back to where you started with just using the left side of the screen.
I tried out the DVD player last night. Took me a minute to figure out that the electronic parking break needed to be applied. Sound with ML is amazing!
it is too wide yeah, so there would be no point...
