Official 4GS Modification Thread
Old 01-30-21, 09:50 AM
  #691
lexus4jess
lexus4jess's Avatar
FYI, the F Sport pipe is not polished. It has a chrome powder coat finish. When it got welded, it burnd off the clear coat it had on.
Old 01-30-21, 10:09 AM
  #692
IntrinoX
IntrinoX's Avatar
nice work.
lexus4jess (01-31-21)
Old 04-22-21, 05:03 AM
  #693
MrEuRO85
MrEuRO85's Avatar
Default Frontip installed
Finally got my front lip put on! Not bad for eBay
lexus4jess (08-05-21)
Old 05-27-21, 08:31 AM
  #694
SBPhoto
SBPhoto's Avatar
Originally Posted by GTGS350F
Hey guys and gals,
I don’t usually post but I would like some advice from the ones with knowledge.
I REALLY want to purchase an aftermarket air intake for 2014 GS 350 F-Sport, but I have no clue what to get. I had previously purchased the K&N Typhoon Air Filter and I really didn’t like it and returned it.
I’m torn between AEM and HPS, but if there are other options out there I’m open to them. Thanks for any advice.
Here is a couple of pics of my beautiful car 👇😍
Clean *** ride!
When it comes to an intake this is just my experience/opinion. The stock air box is fed by a inlet behind the front grille, and the filter is enclosed keeping air temps from the engine bay out. I was told from shops that sell takeda and other intakes that all you get is sound and the filter is now exposed to under hood temps because there is no more box. If you just want sound, takeda and those types are the way to go. I got a reusable/washable high flow AFE dry filter to put in the stock air box. I gained a couple MPG and remember the car feeling slightly better.. but I like that its getting cold air from the grille inlet.
fhan888 (04-10-23)
Old 05-28-21, 05:52 AM
  #695
HueRok
HueRok's Avatar
Default Staggered 20s wanted ASAP!
Originally Posted by BkRed350
SWEET
Could someone point me in the right direction as to where I can get these wheels? I’ve been looking for days..
thanks
Old 06-11-21, 03:23 PM
  #696
Dro0011
Dro0011's Avatar
Default New Wheels- Need Coilover suggestions please
Recently got a new pair of wheels/tires - I left a photo of the tires label for brand/specs et all.
Wheels are Curva C300 18x9.5
Tires/Wheels fit almost flush- Personally I think they look amazing on the GS350 F Sport
The tires at this size fit well with the car- there is slight rubbing in the front tires at a full turn- it's not much that rubs and I'm confident I can just cut out the parts on the front bumper that are touching.
No issues with back tires.
The ride definitely feels heavier than before- I do notice I need to press a bit more on the gas to get it moving- The ride is much much smoother for passengers tho! you feel the road a lot less as a passenger. the only problem I think I have with the feel of the ride is that
I'm currently sitting on STOCK suspension- I definitely need a tighter suspension to go with these big tires.
Does anyone have any suggestions?? I'm looking for the following:
- Keep the same ride height. It snows heavy where I live and this height is perfect to avoid getting stuck
- I don't want a full on sporty suspension. I'm looking for a balance of something only slightly tighter. My main priority is keeping the ride smooth (I will be installing some very sporty sway bars for cornering/turns but they don't really affect the feel of the ride when driving normal)
The following 2 users liked this post by Dro0011:
blackangus (09-27-24), mommings350 (01-10-24)
Old 06-11-21, 03:25 PM
  #697
Dro0011
Dro0011's Avatar
could you drop a link to where you got your AFE dry filter?
Old 06-11-21, 03:53 PM
  #698
Dro0011
Dro0011's Avatar
OEM 2019 F-Sport washer fluid reservoir.
2015 GS washer fluid reservoir. smaller size.
Anyone know what this cable for? White and white/black stripe. would this be the option for fog power cable?
Bought the spyder fog light kit. and installed OEM lexus fogs ( koito ) throw away the cheap led fogs that can with the kit.
Faster to install when you remove the bumper cover.
Done. Now i have to wire them up. That will be for another day. Tired, been raining.
Looks great! I'm curious how to control the fog lights? or do they just turn on whenever the headlights are set to turn on?
Old 06-11-21, 04:21 PM
  #699
Dro0011
Dro0011's Avatar
Looks sick!! where did you get them??
Old 06-24-21, 08:00 AM
  #700
lexus4jess
lexus4jess's Avatar
Installed the OEM stack fog switch on the steering column. I posted a video on you tube on how they work.
Old 06-24-21, 08:03 AM
  #701
lexus4jess
lexus4jess's Avatar
Bought the kit on ebay. The kits led lights suck. I put lexus OEM LED fogs. I just needed the mounting brackets.
Old 11-02-21, 02:35 AM
  #702
Hova163
Hova163's Avatar
Default Nice.
Originally Posted by djpeakSD
Plastidip bumper and trim!
I’m doing the same but I’m painting mines black
Beatmd (05-27-23)
Old 11-02-21, 02:39 AM
  #703
Hova163
Hova163's Avatar
Default Washer fluid
So u changed the washer fluid tank to a smaller one? Because I have a 2015 GS f sport and that tank won’t allow me to put the bumper back on with the fog lights I purchased.
Old 02-06-22, 11:24 AM
  #704
lexus4jess
lexus4jess's Avatar
sorry for the late reply. Yes I had to put a smaller washer tank.
Hova163 (02-06-22)
Old 02-06-22, 03:32 PM
  #705
Hova163
Hova163's Avatar
Default Washer tank
Where did u order it from or bought it?
Quick Reply: Official 4GS Modification Thread
