DVD while driving
#31
just removed my old unit from my 2008 ls 460.. one problem.. now says check srs.. airbag and no function controll on the dash for the audio and climate.. no eject on the cd player.. any thoughts.. do we think the installer i had removed the unit messed up.. i know that is a yes.. but do we think a fuse or issue when removing the pNP and put back to factory?
thansk
thansk
#32
exclusive matchup
thansk
thansk
i have removed a lot of kits before and never a problem
#37
Hello. Im new to this. Never owned a lexus. Just picked up '
'13 gs350. So what is that dvd bypass system called and where do i order it? I wish they had something for bypass navi while driving, and reply txt would work.
Thanks
Thanks
#38
exclusive matchup
http://www.prestigioussociety.com/?page_id=138
#39
I am interested in doing the nav mod on my GS F sport. Anyone have a pictorial on the install or can post or pm me the instructions from PS instructions they send with the unit?
Want to know if this is an easy mod i can do.
Thanks!
Thanks!
#40
I don't remember where it is, but they send you step by step instructions when you order the unit.
Basically, you remove the radio trip by pulling
Remove 2 bolts, pull the radio unit out.
Remove the plugs from the back
Plug in two plugs from the PS module (the new version is only 2 simple plugs)
Re-insert all plugs
Put the radio back in
Re-insert bolts
Put the trim piece back in.
If I can find the instructions I will scan them in and post them.
Re-insert all plugs
Re-insert bolts
#44
Re-insert all plugs
Re-insert bolts
Re-insert all plugs
Re-insert bolts
