lane change blinker
#47
Took me a few tries, but I was able to change it to 5 blinks.
#48
Success!
Thank you for your post. I had tried this procedure several times and could only get it to work up to Step #4 until I saw your post. It appears that Step #5 should actually be Step #1. When I performed step 5 first, it worked great and I was able to change the the lane change from 3 to 5 blinks.
#50
Not working for me
I tried step 5 as step 5 , and also step 5 as step #1.
But I am getting the one right signal indication
Which means I am doing some thing right, but not quite right
#51
Just did this myself (5 blinks) and it took a few tries to get it right. The official procedure can be a little confusing to understand, and you have to do it pretty quickly as well. There is also a step they have listed in the middle that you can actually do before you start the time-critical portion, so it's easier if you do that first. I'm going to try to describe what I did in case it helps anyone:
1. Start with the car completely off
2. Use the rotary **** on the wiper control to set how many blinks you want. This **** has four positions:
- 1st (bottom) position = 3 blinks
- 2nd position = 5 blinks
- 3rd position = 7 blinks
- 4th (top) position = no automatic blinks
3. Hold the wiper lever in the all-the-way-up position, and keep holding it there
4. With foot OFF brake pedal, press the start button twice so the gauges light up (keep holding that wiper lever up!)
5. Continue to hold the wiper lever all the way up for 5 seconds or more (if you go too fast you will have to start all over!)
6. Let the wiper lever come down one position and hold it there for 5+ seconds (don't let it go back to the middle, just let it come down one position)
7. Hold with wiper lever all the way up again for another 5+ seconds
8. Let with wiper lever come down one position again, and hold it for 5+ seconds
9. Let go of the wiper lever. The right turn signal should flash once. If it doesn't, turn the car off and start again at step 1.
10. Briefly move the turn signal lever down 1 position and let go of it again.
The left turn signal should flash to confirm your setting, but not in the way you might expect. It will blink 1, 2, 3, or 4 times to match where you set the rotary **** on the wiper control, so:
- 1 flash = set for 3 blinks
- 2 flashes = set for 5 blinks
- 3 flashes = set for 7 blinks
- 4 flashes = no auto blinks
The following 8 users liked this post by FishBike:
heshamos (09-22-18),
IcyBishop (03-29-18),
logjammin (07-12-23),
MiciasMica (09-11-17),
mjo13 (04-17-23),
and 3 others liked this post.
#53
Thanks! Just did it and it worked perfectly the first time.
#56
#57
That does sound like witchcraft. But what if there were an app for that? I'm trying to develop an Android app that does exactly this: allows you to customize settings like the lane change blinker count. It's not released yet, but it's ready for testing. Would anyone be willing to give it a go? You'd need an ELM327 bluetooth adapter, but those are cheap and easy to get. Lemme know.
#58
Worked perfectly the first time! Thanks so much for this detailed yet simplified instruction. 5 blinks is perfect!
#59
Work like a charm
Thanks a lot
All I was missing was step #10
