lane change blinker
Old 07-26-20, 09:27 PM
  #106
LexusGSboy
LexusGSboy's Avatar
Originally Posted by FSportOnly
This thread is golden. Changed mine to 7 blinks. Three was never enough.
I've been trying 5 - I think I"m about to go to 7. I guess I just don't merge fast enough
Old 01-11-21, 12:27 AM
  #107
jsanders
jsanders's Avatar
I changed mine from 3 to 5 using the pdf. Extraordinarily helpful thanks for posting it!!!
Old 01-11-21, 03:57 AM
  #108
byungkuk
byungkuk's Avatar
Been on 5 since I learned of this switch.. it's the best!
Old 01-11-21, 07:12 AM
  #109
00goobs
00goobs's Avatar
Thank you! Just changed to 7. I love using my blinkers. I couldn't find this option on techstream or my aftermarket scanner. I did the windows with the remote with my scanner, but could only find DRL on/off in reference to lighting....
Old 01-18-21, 06:59 PM
  #110
xshurikx
xshurikx's Avatar
Hey all, just picked up a 13 GS350 AWD, did this and it worked changed to 5. has anyone figured out how to change this to same direction cancel and 5 clicks?
Old 01-19-21, 04:54 PM
  #111
LexusGSboy
LexusGSboy's Avatar
I'm not sure I understand the "has anyone figured out how to change this to same direction cancel and 5 clicks" question.
I have a 2016 so maybe it's different. Soft click does lane change, hard click does standard turn.
If you want to cancel either of those you soft click the opposite direction I thought? Is that different from what you're asking?
Old 01-19-21, 06:37 PM
  #112
xshurikx
xshurikx's Avatar
What I wanted to know is how to change it to same direction cancel. Basically if I change a lane but did a hard click and need to cancel I want it to be same direction not opposite
Old 01-19-21, 07:41 PM
  #113
LexusGSboy
LexusGSboy's Avatar
Ah...I didn't even know that was possible.
I found this post 36 in this thread but reading things around it I don't know if I know the answer. Some seem to suggest that if you can't have both the lane change (3,5,7) and same direction cancel at the same time, others seem to say you can.
Anyone know for sure?
Old 06-20-21, 08:14 PM
  #114
Shagwell23
Shagwell23's Avatar
Originally Posted by caddyowner
Saved, thank you.
this link is now dead, Any chance you still have the pdf? Thanks
Old 06-20-21, 08:43 PM
  #115
Shagwell23
Shagwell23's Avatar
Can the blinker be modified this way on a 2013 rx350?
Old 06-21-21, 01:53 AM
  #116
PhilC13
PhilC13's Avatar
I don't have the PDF, but maybe this screenshot will help
Old 06-21-21, 07:40 AM
  #117
Shagwell23
Shagwell23's Avatar
Thanks for the screen shot. I tried it a bunch of times, but it doesn't seem to work for the rx350 2013. If anybody has gotten it to work on the rx, please let me know so I can try again. Thanks!
Old 06-21-21, 01:18 PM
  #118
LexusGSboy
LexusGSboy's Avatar
Did you remember to do it from the passenger's seat, only using your left hand, while wearing a blue polo shirt, and keeping your right index finger on your nose?
Sorry - I couldn't resist - when I did this it seemed like the instructions should have at least a couple of those things included....
But seriously - it took me three or four tries to get it. I finally realized it has you doing all of these things with the wiper lever and then the VERY last one is with the turn signal indicator. I was doing the wiper lever for step 10 which of course wasn't right . Once I figured that out it worked. I don't know if that may be the issue or if the RX is different but I figured if my mistake helped someone else than it was a good thing!
Old 06-21-21, 02:48 PM
  #119
JDR76
JDR76's Avatar
Received 1,631 Likes on 1,038 Posts
When I had my 2013 RX350, I had to change it through Carista.
Old 06-21-21, 09:05 PM
  #120
Shagwell23
Shagwell23's Avatar
Ah, right index finger ON the nose. Mine was IN the nose 👃
Thanks for all your helps. No luck getting it to work on the rx. Gonna try to buy the diode dynamics led flasher. Would have been nice to do it without purchasing and installing accessories, but oh well. I got used to the feature on my Infiniti, its hard not to have the one touch blinkers
Quick Reply: lane change blinker
