Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus: How to install HID Headlights (on your non-HID equipped 2IS)
Step by step instructions for do-it-yourself repairs
Fog Light Bulb Replacement Question
Did you need anything in addition to the bulbs? (or was it just a simple switch of the bulbs?)
Regarding your comment about these being too bright, are you concerned about these generating too much heat and damaging the GS's fog light enclosure? or is it due to concern about it blinding oncoming traffic?
Or is it just that incredibly bright?
Thanks Bill_GS3.
Or is it just that incredibly bright?![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
The brightness concern seem to stem from the scattering of the light, it spreads out more. Also the halogen bulbs have that black tip where as the LEDs actually hav LEDs on the end.
I think the light may be an issue with oncoming traffic, but have not gotten anyone flashing at me yet.
So I am probably going to pre-order these: http://www.vleds.com/bulb/h-series/h...-pair-b-o.html
Can anyone on here confirm all I need to do is simply place these into the Nigel JDM fog's I had installed on my F-Sport?
Thanks.
Thanks.
Thanks.
Thanks.
Once you pop out the lower bumper liner just reach up inside and grab the back of the bulb and twist to the left. You can watch your progress through the lens. Once it's out and visible, remove and replace. When you re-install again watch through the lens as you line up the three tabs. Once lined up push in and twist right. Replace the three bolts and repeat on the other side (which will take half the time - steep learning curve). VLEDS H11 5k is a great replacement bulb BTW.
Here is an excellent DIY on the LED conversion put together by CL user GregCanada here: https://www.clublexus.com/forums/gs-...og-lights.html
~ Im2bz2p345
~ Im2bz2p345
Yes 4GS uses H16.
