Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus: How to install HID Headlights (on your non-HID equipped 2IS)
Step by step instructions for do-it-yourself repairs
Fog Light Bulb Replacement Question
#33
14 models still use the H11.
It may be a little old and redundant question and I apologize for that, but what is the best bulb suggested here?
I found this one on eBay, which is a little pricey:
http://www.ebay.com/itm/400637344696?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Have anyone got an error code after changing the H11 halogen to LED?
#34
Not sure about this particular eBay one but I tried a few. Not worth it. IMO you should either get the new stock LED or VLEDs. I have the new LEDs on our RX. They look nice and clean but I personally prefer the round one. VLEDs are the best plug and play IMO. The first picture is stock and second is VLEDs.
#36
http://www.ebay.com/itm/371285443211?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The light output is pure white with no hint of blue, just like Lexus with factory LED, instant on and almost as bright as 55W HID. I'm currently have this on high beam for my Sienna but the H11 will fit the fogs on many Lexus and Toyota. This is the same as Vleds LMZ currently selling for $250/pair.
There will be no error code for changing from halogen to HID or LED.
#38
#39
Has anyone used these Phillips Xtreme LEDs, http://www.usa.philips.com/c-p/78719...n-led-fog-lamp
#41
Resurrecting this thread...has anyone tried these fog light replacements from VLED?
http://www.vleds.com/shop-bulb-numbe...ght-bulbs.html
If so, how are they? Thanks!
#42
They provide a better overall "match" to the hids - not exact but much better. For $60, they are great for giving you a better white light, they are a quality product and its def. the easier route than going with a fog / HID conversion.
conclevage (01-17-17)
#43
Have the previous generation of that VLED bulb in my pop's '11 GS350. The light output seems just as good as the halogens they replaced (but actual usable light and cutoff may fall a little short of standard halogens).
#44
Good to hear...will probably get them for the color match with the stock headlights...any other replacement bulbs that anyone recommends for an easy direct-swap? I don't want to do the fog/HID conversion...did that with my last GS after initially installing SilverStars.
Puddle Bulb (2): VLED 194 bulb
Door Courtesy bulbs (4): VLED 194 bulb
Reverse Bulb (2): VLED 921 bulb
Trunk Bulb (1): iJDMToy LED Strip (https://www.amazon.com/iJDMTOY-18-SM.../dp/B009K6IW00) OR Diode Dynamics SMD Board (http://www.diodedynamics.com/store/1...runk-light-led)
Be careful though - a few high quality bulb purchases along with the replacement fogs will def. start setting you back some $$$...but why not right??!
![Big Thumb Up](https://www.clublexus.com/forums/images/smilies/biggthumpup.gif)
