Can you use speech commands for “Air Conditioning “ ?
Old 07-01-12, 10:11 AM
Chris8152
Chris8152's Avatar
Default Can you use speech commands for “Air Conditioning “ ?
According to my navigation system owners manual you can control, navigation, audio/video, telephone and air conditioning systems with voice control, but I cant seem to get the air conditioning voice command to work, any thoughts?
Old 07-01-12, 10:35 AM
db3434
db3434's Avatar
If you go into the setting under voice command there's a "advance" command that you need to turn "on" and once you do you can use commands like "cooler" and "warmer" etc.
Old 07-01-12, 10:38 AM
Room4Tu
Room4Tu's Avatar
What are some other advance commands that are available through voice? I have not had a chance to read through this section yet.
Old 07-01-12, 10:55 AM
Chris8152
Chris8152's Avatar
how do you get to "settings under voicecommand"
Old 07-01-12, 11:58 AM
jscgs350
jscgs350's Avatar
I just tried, and works as expected. Saying "warmer" or "cooler' adjusts the temp.
Press your Menu button and go to Setup, and then Voice. You'll then see the Voice Settings menu, so go to page 2. You'll see "Expanded Voice Commands" where you can change the setting to ON.
I would like to know what the additional commands would be, so I hope someone posts when found.
Old 07-01-12, 12:16 PM
Chris8152
Chris8152's Avatar
Thanks for your help
I don’t seem to have a page 2 on voice settings, it must be another one of these country/region differences.
I didn’t have any problems with my MK3, I may pop down to my dealership tomorrow and see what they say.
Old 07-01-12, 01:37 PM
db3434
db3434's Avatar
There's a list of commands in the manual or if you google it. I'll try to find the link again
Old 07-03-12, 12:11 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
You can also specify specific temperatures.
Old 07-03-12, 07:58 AM
GVVTS
GVVTS's Avatar
Sorry, not on the North American Generation 7 systems.
Here are the expanded voice commands:
“Radio” Sets the audio mode to radio.
“AM” Selects the AM band.
“FM” Selects the FM band.
“Satellite radio” Selects the satellite radio mode.
“Disc” Selects the disc audio mode.
“Auxiliary” Selects the auxiliary audio mode.
“Bluetooth* audio” Selects the Bluetooth® audio mode.
“iPod” Selects the iPod audio mode.
“USB audio” Selects the USB audio mode.
“Audio on” Turns the audio system on.
“Audio off” Turns the audio system off.
“Automatic climate control” Turns air conditioning on and off.
“Warmer” Turns temperature up.
“Cooler” Turns temperature down.
Old 07-03-12, 10:17 AM
jscgs350
jscgs350's Avatar
Nice, thanks!
- JC
Old 07-05-12, 06:06 PM
gyung
gyung's Avatar
Does the GS navi keep giving you instructions every time you use the voice command? I know you can press it one more time to skip it but is there anyway to turn it off?
Old 07-05-12, 06:51 PM
Vasili
Vasili's Avatar
You can delete your destination through voice command.
Old 07-05-12, 06:58 PM
gyung
gyung's Avatar
What I meant by that is, everytime I press the VC button, it says "Say blah blah blah to do this". You can press the VC button again to interrupt it but it's kind of annoying.
Old 07-05-12, 07:12 PM
Vasili
Vasili's Avatar
Yes, it does get a little annoying.
I thought the VC in the newer Acura had better response. Hopefully, Lexus fixes this.
Old 07-05-12, 07:28 PM
GVVTS
GVVTS's Avatar
You just need to turn voice recognition prompts off. The next time you push the talk button you will see the button on the left side of your screen called "Voice Prompts"; select it to turn off the voice prompts.
Quick Reply: Can you use speech commands for “Air Conditioning “ ?
