Getting ready for my 5k service, any dealer only settings I should turn on?
Old 08-25-12, 07:33 AM
zoombie99
zoombie99's Avatar
If you are a male, I would warn you about the key fob window opening. I had to have it turned off on my 3gen because I left the keys in my pocket and sometimes I would go out to find all the windows down including once in a heavy rain storm. I guess the fob got pressed in my pants pocket.
Old 08-25-12, 08:36 AM
LexusGSFGO
LexusGSFGO's Avatar
On the 4G you have to hold the button down the entire time, and it doesn't start until after a few seconds. I don't think it's possible to do this accidently.
Old 08-25-12, 10:50 AM
ECL
ECL's Avatar
Originally Posted by LexusGSFGO
I agree with the doors/sunroof open with key fob. That and the lane change blinker setting from 3 to 5 or 7 was what I went for, but he dealer could not do the latter. I finally did it myself with the DIY instructions from this forum. However when the service guy and I were trying to find this setting, I discovered an unlisted one that the dealer can do. It's a setting to turn the blinker volume to low. The settings are low, med and loud, with loud being the default. I highly recommend this change. Good luck.
When you get a little older, you will appreciate the louder blinker Volume. It will keep you from driving around all day with the blinkers on!
Old 08-25-12, 01:03 PM
LGSFS2012
LGSFS2012's Avatar
Is there a DYI for the windows FOB? or only dealer?
Old 08-25-12, 03:25 PM
Winson6628
Winson6628's Avatar
I didn't know they didn't come already programmed, well looks like I'll ask them to do it on my 10k maintance, since I already done my 5k. How u lower the volume on the blinker? I'd like to have that lowered. But it doesn't bother me tho.
Old 08-25-12, 07:41 PM
LexusGSFGO
LexusGSFGO's Avatar
Only the dealer can program the blinker volume and the windows/sunroof FOB control. They are both done via the "data stream" by connecting their diagnostic tool to the Car's OBD port under the steering wheel.
Old 08-26-12, 07:33 AM
Winson6628
Winson6628's Avatar
Ok I gotcha, well I'm going to get it done my next service which is 10k. Thanks for the info man!
Old 08-27-12, 01:35 PM
TitanFan
TitanFan's Avatar
Does the car have to be on? Because I can't it to work. I am following the steps exactly. Please help!!!
Old 08-28-12, 07:29 PM
TitanFan
TitanFan's Avatar
you can program your key fob to pair up with your memory seating. if thats what your asking obadea. For example key fob 1 can be paired up to memory seat position. So whenever that keys comes near the car that is the memory seating it will go too.
Old 09-02-12, 11:43 AM
mso4
mso4's Avatar
Originally Posted by obadea
- adjust memory seats from any door (default is, the seats only auto-adjust if you unlock the driver door) I forgot about this one and I'll probably have to pay now.
Had my 1k ck up done. Dealer was not able to add this feature. He said it showed up in the menu but it did not worked when he programmed it. No biggie since I prob won't need to use that feature much.
GsDreamz
10-16-17 10:39 PM
Missypoo
07-24-17 07:13 AM
dougm213
02-06-14 03:52 PM
HD-GS4
02-19-05 08:32 AM
Quick Reply: Getting ready for my 5k service, any dealer only settings I should turn on?
