Dont tap it to the sub out. the crossover point in the gs is horrible. The best way is find where the factory amp is and take the left and right rear speaker ch bridge it into a loc. That way u get full control of the crossover from your amp. Also make sure u tap it before the factory amp not after.
For ML, do you know which wires are the two front speakers? Going to be tackling this install in the next couple weeks when I get some time
Cool thank you! Did you bridge these into one LOC for your sub?
Yes, used these leads into the LCQ1...in a sealed enclosure, firing thru the ski hole in the trunk. changed out the door speakers to Boston Z's, changed out the rear doors to boston pros. total weight of amp rack/box/eq is less 23lbs. built enclosure using fiberglass. will post pictures soon.
