Grab the Visine - red out tail lights
Yup that is the correct auction. Here's more detailed steps:
- Clean the tail-light very well. Make sure there is no wax or anything on it.
- Prepare a solution of water and shampoo - put about 4 drops into it (baby shampoo works the best). Fill the rest with water - just use a standard spray bottle.
- Spray down the tail light and your hands with the water solution. Peel off the vinyl and spray water on both sides also.
- Position the vinyl on the tail-light. If its not right peel off and do it again, make sure that it is plenty wet.
- When you think you have it centered, start from the middle and push out any extra water or air bubbles. Do this gently as I used a squeegee and it marked up the vinyl. I just used my fingers instead.
- Repeat on the other side and then pat yourself on the good work you just did
Thank you for taking the time!
Hopefully I can return the favor one day.
Bullskim
03-20-08 12:11 PM
yellowssm
03-16-06 09:40 AM
