Changing to L.E.D Lights
Anyone have any DIY's or advice on changing the front/rear turn signal bulbs, and reverse light bulbs? I bought all LED's and recently saw another thread on here about someone changing these out, but didn't understand exactly what or how it was removed. I'd eventually like to change those cheap puddle lights and trunk light as well.
[QUOTE=Mi1lion;7544789]Anyone have any DIY's or advice on changing the front/rear turn signal bulbs, and reverse light bulbs? I bought all LED's and recently saw another thread on here about someone changing these out, but didn't understand exactly what or how it was removed. I'd eventually like to change those cheap puddle lights and trunk light as well.[/QUOTE
Front and Rear turn turn signals I would not touch it, the rears are LED are part of ur taillight, u can change ur reverse one only , it very easy, just pop the 2 clipsd off the cover and u will see a socket, twist and take it out, and ur done.I know the fronts u have to take a headlight out if I am not wrong.good luck.
Ok well the two reverse lights are part of the whole light assembly right? So would I have to remove the trunk lid liner in order to get to the back? I know that there's 2 black nuts on either side, but when I took them off the light assembly (just on the trunk lid) didn't budge which led me to believe I have to get on the backside of the liner. Does anyone know how to remove those weird plastic button/clips. I didn't want to go prying on something and it break off. Do you have to squeeze and pull or do something special to them. I know that when I had my R1 you pushed the centers of the clips in, then pull them out. But these buttons have indentations on either side, as if there supposed to be squeezed while pulling.
4urxtc
SC- 1st Gen (1992-2000)
33
04-24-11 05:32 PM
ToyotaLexus
RX - 1st Gen (1999-2003)
02-24-09 10:10 AM
