Replacing the top grille with the F-Sport Grille
Old 08-26-18, 12:41 PM
  #91
UDel
UDel's Avatar
Resurrecting this older thread to go with the new thread discussion on switching out grills. So does anyone have any more information, tricks they learned. Looks like from reading the bottom will fit but you need to modify it a little, cut some tabs. From what some seem to say they did not need to remove or loosen the bumper to do this which is different from some of the other information I have read. Hope you don't.
Old 11-01-18, 02:14 AM
  #92
rimini
rimini's Avatar
Yes, I would really also like to know what tabs has to be cut on the lower grille to make it fit ?
Old 11-01-18, 02:22 AM
  #93
peasodos
peasodos's Avatar
Received 2,228 Likes on 1,450 Posts
It's much easier when you take the bumper off. You compare the original grill to the f-sport and then you'll know exactly what tabs to trim.
Old 11-01-18, 02:29 AM
  #94
rimini
rimini's Avatar
Ok, will start the process...
and the upper part nothing to be trimmed?
Old 11-01-18, 02:32 AM
  #95
peasodos
peasodos's Avatar
I don't remember but I think I ended up trimming something. Again when you install it you will see what tab is not fitting right and needs to be trimmed.
rimini (11-01-18)
Old 07-01-19, 05:59 AM
  #96
Zsikd
Zsikd's Avatar
Peasodos - just a quick question - where did you get the grills from? Are those OEM from Lexus? Thanks!
Old 05-30-24, 02:29 PM
  #97
cesarpagan2797
5th Gear
cesarpagan2797's Avatar
Hello, what did you use to chrome delete the fog light trim?
elane77
07-29-22 12:28 PM
caesosa
IS C
02-14-20 10:31 AM
EvilJoker
02-06-19 05:53 PM
BobsIS350C
06-04-15 10:52 AM
BernieIS
IS C
04-25-13 05:41 AM
Quick Reply: Replacing the top grille with the F-Sport Grille
