DIY puddle light led
Old 12-29-17, 09:18 AM
  #271
jordanhigg
jordanhigg's Avatar
[QUOTE=16GSF00336;10066737]That 3rd bulb could fit...Its the length thats the concern...I myself wanted to put the Biggest/Brightest...However, the I bulb I end up with is Super Bright...[/QUOTE
Which bulb did you go with?
Old 12-29-17, 11:35 AM
  #272
EyeKutr
EyeKutr's Avatar
Originally Posted by biglexfan
Could you share with us where you bought that far left bulb?
How would you describe the colour of that bulb, i.e. is it pure white similar to the instrument dials or does it have a bluish tint typical of most white LED bulbs found on ebay.
It is slightly bluish, but overall very nice
It was on ebay, search for this
2Pcs License Plate Light Auto Bulb T10 Canbus 194 921 COB W5W LED for Benz BMW
current link https://www.ebay.com/itm/2Pcs-License-Plate-Light-Auto-Bulb-T10-Canbus-194-921-COB-W5W-LED-for-Benz-BMW/152575671115?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Old 12-29-17, 11:39 AM
  #273
EyeKutr
EyeKutr's Avatar
Really all of these would fit, there is room. What is important is to find a bulb that puts light out to the side as the bulb sits sideways in the housing Hence this two sided flat LED is ideal. That 3rd bulb is disappointing compared to bulb 1 tbh
Old 02-10-18, 04:34 PM
  #274
veez81
veez81's Avatar
Originally Posted by tejanp
after doing this mod, my driver's side mirror shakes a lot now. this is also the same side that had the glue. Anybody else experience this ?
having this problem on my driver side, now too. did you ever figure out what caused it? i took it apart and reassembled it, everything seems to be lined up properly. i noticed that if i tightened the screws stronger, the rattling is more noticeable. can't figure out what's causing it.
Old 02-14-18, 06:15 AM
  #275
tejanp
tejanp's Avatar
Pointed it out to the dealer during my oil change and they replaced the whole mechanism under warranty for free.
Old 02-14-18, 11:01 PM
  #276
EyeKutr
EyeKutr's Avatar
You probably did not have the mechanism snapped on properly (mirror on clips).
tejanp (02-15-18)
Old 02-15-18, 06:55 AM
  #277
Superman60
Superman60's Avatar
So what is the consensus on which bulbs to use, I like Vleds will they project good bright light?
Trying the vleds 194's we'll see..
Old 02-15-18, 11:07 AM
  #278
tejanp
tejanp's Avatar
the head technician removed the mirror, reinstalled it and the problem still persisted.
Old 06-30-18, 10:57 PM
  #279
Speed3381
Speed3381's Avatar
Omg...I'm trying my best to pull the mirrors out (Step 1) but I can't get it off. I don't want to crack the mirror also. I'm pulling so hard and no result. Any tips guys?????
Old 06-30-18, 11:11 PM
  #280
yardie876
yardie876's Avatar
Pull harder lol. It takes an unnerving amount of force to get it off. I tilted the mirror in such a way that I could get my fingers in the top inner corner and pull the mirror away from the car.
Old 07-01-18, 02:01 AM
  #281
Speed3381
Speed3381's Avatar
im pulling and pulling but I feel so scared I’m going to either crack the glass or break something underneath it 😓
Old 07-01-18, 02:59 AM
  #282
Speed3381
Speed3381's Avatar
Anyone in the Bay Area want to help a member out? LoL 😂
Old 07-01-18, 09:50 AM
  #283
bclexus
bclexus's Avatar
Received 2,180 Likes on 1,562 Posts
It may be hard for you to believe, but you really are not pulling hard enough. Apply constant, ever-increasing, pulling force until it releases. Change your mindset to where you are intentionally trying to break something - and you'll safely remove the glass.
Old 07-01-18, 10:08 AM
  #284
Speed3381
Speed3381's Avatar
Do I just keep pulling as hard as I can or do I need to use my fingers to unattach something from behind? 😓 Please help. Thank you.
Old 07-01-18, 10:33 AM
  #285
bclexus
bclexus's Avatar
Do I just keep pulling as hard as I can or do I need to use my fingers to unattach something from behind? �� Please help. Thank you.
Remove the side mirrors by first turning them as far outward from the car as they will go, then point the glass mirror up as far as possible so that it's reflecting the sky. Grab the bottom of the mirror with your fingers and pull up and towards your body.
If you are not familiar with how the mirror is held in place it should help you to see that there are four tabs (see image below) that hold the mirror in place. As you apply pulling force the tabs will most likely release individually at the location where you are able to apply the most force, which will likely be the bottom tab closest to the car door first, and then the other bottom tab furthermost from the car door, then the upper two tabs will likely be the last to release.
Quick Reply: DIY puddle light led
